06-16-2006, 07:55 PM | #1 |
Cause of leaky pinion seal?
I pulled my pinion yoke because I noticed a small leak, after about an hour and a half with a hammer, a slide hammer, and a two jaw gear pulled I finally got it off. I looked at the seal I pulled out, it didn't look too bad, didn't notice any big cuts or anything. Next I cleaned up the pinion yoke, and noticed that there is some surface rust and gaulling on the surface closest to the dust boot, I included a pic, its not too clear (camera sucks), is this the cause of my leak? If so, is there anything I can do with this yoke?
There also seems to be a groove about 1/8th of an inch up from the flat surface that is parallel with the dust boot, not sure if this is from debris or the seal, not sure how far forward the seal sits on this surface once installed in the case.
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
06-16-2006, 08:01 PM | #2 |
18 Till I Die
Re: Cause of leaky pinion seal?
Go buy a speedy sleeve and a new seal and put her back together. Did you mark the nut to the pinon stub?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
06-16-2006, 08:40 PM | #3 |
Make sure that the vent is open and not plugged up. A plugged vent will cause a build up of pressure in the differential which leads to leaking seals.
Jim |
06-16-2006, 09:08 PM | #4 |
yup ..hope you maked it..other wise !!!
that nut requires something like 200-220 ft lbs depends on which rear end you got. and thats setting the crush washer in there. thinking its new. or you will get a howl..be carefull on this one. |
06-16-2006, 09:58 PM | #5 |
What's a speedy sleeve, do I have to turn the OD of the pinion yoke?
Do I need a new crush washer? The washer I pulled out of there looked to just be a solid washer? Last problem......I didn't mark the nut, I was unaware that I had to....BUT when I bought this axle the nut could be tightened or loosened by hand anyway (think PO probably tried to replace the seal and they weren't as determined as I was to get the yoke off). Oh, lastly, I am still working on getting this axle installed on the truck, so I don't think pressure build up (truck hasn't moved) is the cause of the leak, but thanks for the tip, I will check that tube before I run it.
06-16-2006, 10:06 PM | #6 |
Re pinion nut torque: Guys, the big torque numbers you describe are for crushing the sleeve initially. (The sleeve is behind the tapered bearing.) Once it's crushed to achieve the proper pinion bearing preload, it's done. I mean, what's the sleeve gonna do, expand? The only reason to re-crush would be if the pinion bearing preload has loosened up too much. But you can't measure and adjust that without removing the axles and carrier.
I would clean the pinion and nut threads really well, squirt on some red Loctite and tighten the nut down to 125 lb/ft or whatever the spec is. It probably took 300 lb/ft to crush the sleeve, so 125 isn't gonna crush it any further but will hold the yoke on securely. I use a 24" pipe wrench to hold the yoke while torquing the nut.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 06-16-2006 at 10:07 PM. |
06-16-2006, 11:55 PM | #7 |
18 Till I Die
Some times you can "feel" the point of where the nut comes in contact with the crush sleeve. Then just give it a little more like a minute or two. Not like 15 minutes. The only other option is to remove the carrier and the pinion, then install a new crush sleeve and retourqe to spec. The only function of the crush sleeve is to hold the nut on. Take the yolk to a parts store and ask them to match up a speedy sleve for it. No turning of the yolk. I have just hammer them on and it gives it a new surface for the seal to ride on. Good as new. I have done lots.
06-17-2006, 12:26 AM | #8 |
Oilfield Trash
Leaky seal might have meant the pinion bearings were a bit lose, nut may have backed off, this just happened to me on my 98
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
06-17-2006, 12:29 AM | #9 |
Sandwich: Club
Yeah, don't forget the loctite. I did this a few months ago and after reading all the scary sh*t about marking the nut/ pinion crush preload/ destroying diff if you overtighten/ etc. I was a bit shocked to find that I could loosen the pinion nut by hand......guess the PO (or somebody) didn't add the chemicals to the nut when they put it back on.....I'm guessing the loctite is causing all the grief for the folks struggling to get the pinion nut off....just a guess tho
06-17-2006, 01:32 PM | #10 |
Pinion nut is a locknut. Just replace it. Best advice above is to get snug, the as tight as you can using a 1/2" ratchet.
06-17-2006, 03:31 PM | #11 | |
My main point was the crush sleeve doesn't even come into play here, so I didn't understand why several folks mentioned it. Shelby -- simply do what Mike C. says.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
06-17-2006, 04:04 PM | #12 | |
18 Till I Die
The only function of the crush sleeve is to hold the nut on. It keeps pressure on it so it wont come off. You can even run without one if you get the rotating torque/depth to spec then tack the nut, but then its is permanent and that would be silly.
03-17-2010, 10:44 AM | #13 | |
Would this be true if replacing the bearing too? Is there any reason why the crush sleeve would be replaced?
03-17-2010, 11:59 AM | #14 | ||
"I ain't nobody, dork."
The leak is prolly due to the deep grove in the area where the seal rides on the yoke. New sleeve, and a new seal, and good to go.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
03-18-2010, 10:31 PM | #15 |
454 MAKES IT ROAR
What's the sleeve that everyone is talking about? I replaced my pinion yoke and seal a few mths back, and did not see any speedy sleeve that was needed. What am I missing here?
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
03-18-2010, 10:55 PM | #16 | |
http://www.alliedbearings.com/mfg_pr...edi/index.html
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 03-18-2010 at 10:56 PM. |
03-18-2010, 11:25 PM | #17 | |
454 MAKES IT ROAR
Cheers mate.
03-18-2010, 11:27 PM | #18 |
The crush sleeve is NOT to hold the nut on. It is to set pre-load on the pinion bearings. They are tapered bearings. If there is no pre-load on them they will wear out and cause unwanted "play" in the rearend. There is a turning torque spec to be followed when dealing with crush sleeves. Email me if you would like more info and I will try to find specs and give you a better explanation. Too many people do this incorrectly and cause themselves trouble down the road.
02-25-2011, 08:53 PM | #19 |
completly agree with the last post pulling the crush sleeve all toghether and tacking the nut is bad news hopefully you do some research or you'll have bigger issues than a leaking pinion seal
sure bow ties are for little boys ....[B]but ponys are for little girls |
02-25-2011, 11:32 PM | #20 |
Holy year old thread batman.
02-25-2011, 11:43 PM | #21 |
Moderator
Check the first post....it is approaching 5 years old
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 02-25-2011 at 11:44 PM. |
