06-16-2006, 11:31 PM | #1 |
Door windows
Alright I've tried FAQ and a search. How do I remove the windows from my doors? We're down to removing the little stuff in thhe cab now and I would like to remove everything from the doors before taking them off.
please
06-17-2006, 10:10 AM | #2 |
blood type; Retumbo
Re: Door windows
IIRC you roll it down, remove the wing window (by turning it sideways after removing the 2 screws on the front and the lower bolt), then slide it forward off the regulator rollers. next lift it up and tilted to the inside.
I may be a little (or alot) off on this. can someone either prove me wrong or verify this? its been a couple years since I did mine. |
06-17-2006, 10:20 AM | #3 |
Re: Door windows
Sounds right but I thought I tilted mine to the out side away from the body curv. But once you get to this point it will come out. You may also want to remove your findow felts. The kind of side out and up to get them out. This will make getting the window even easier to remove once the vent is gone.
Kevin LFD Inc. |
06-17-2006, 12:36 PM | #4 |
Designated A-hole!
Re: Door windows
You should check the FAQ on window regulator replacement, it's there.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
10-20-2009, 02:55 PM | #5 |
"something witty here"
Re: Door windows
theres alot of resistance in the vent window when I try and turn it sideways Im afraid its going to break it. And I did a search and all that popped up was this thread, Im struggling to get these windows out anymore advice would be appreciated.
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
10-20-2009, 02:57 PM | #6 |
Re: Door windows
K I looked at the faq in your signature and it was there, I wonder why it never showed up when I searched for it
10-20-2009, 03:37 PM | #7 | |
Re: Door windows
I walked out and looked, three screws on top on the leading edge of the door post and you have to remove the door panel to get to the bolt or nut at the bottom of the window guide. Last edited by mr48chev; 10-20-2009 at 03:54 PM. |
10-20-2009, 03:41 PM | #8 |
Re: Door windows
at first I was going by this and it didnt explain those bottom bolts but in the faq window regulator guide theres a detailed description with photos, got them out, now I can enjoy my lunch lol
