Guages
Well i am now ready to put in my new autometer guages. I have never worked on or installed any guages, so any tips on hooking them up would be great, but i think i have most of them except a few questions. My truck never had guages in it, just the wiring harness. Does anyone have a skematic of which color wire does what? Or at least which posistion does what.
I do not have any wires at the sending unit for my fuel tank. How does this hook up? Also i have a TH350 Trans, and a new speedo cable. I put the trans in over the last weekend and am now putting in the new speedo. The cable does not hook up. Its almost like the speedo cable is holding itself up from getting to the guages. There is a stopper on the cable and it is too short so the threads never reach the speedo. Have any of you had this trouble with any speedo cables, in case it matters I got the cable from Brothers Thanks for the help |
#2 | |
Re: Guages
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Re: Guages
I will look around
Designated A-hole!
Re: Guages
Go to the FAQ Submissions page and look on the Index thread, there should be a link to the FAQ you need.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Re: Guages
I just installed a complete set of Autometer Ultra-lite gages in my '68 and I purchased everything from Jeg's. Painless Performance Products has a dash harness specifically for this setup that you can buy at Jeg's or anywhere else for roughly $60 (Part numbers 764-30301 and 764-30302, depending on whether your using a cable driven or electronic speedo). I used it because all of the wires are already cut to length, routed to where each meter is supposed to go (so there's no confusion), everything is color coded (so you know which ones provide a common hot, ground, or illumination inputs), and it gives a really clean final result. Check it out if you're interested.
