Tire/Lift ?
I have a 1982 chevy 1/2 ton 4x4 has a 6 inch lift on it wanting to install a 3 inch body my ? is with 9 inches of lift could i clear 39.5x13.50R15 Iroks i will be putting them on 15x10's if any one has any pics of this combo let me know.
![]() Join Date: Feb 2001
Re: Tire/Lift ?
I would thing you should be fine.
Re: Tire/Lift ?
Are you going to wheel it hard?
I'm running 39.5 TSL's and I rub the inner fenders with a 6/8" spring lift. That's with my springs flattened out pretty much straight. I've trimmed out as far as possible while still trying to keep the 'stock' look of the fenders. Best case scenario would be to trim even farther. |
Re: Tire/Lift ?
what kind of steering box is that kurt?
#5 | |
Re: Tire/Lift ?
http://www.pscpowersteer.com/ Got it from ORD. Last edited by vtblazer; 06-29-2006 at 04:20 PM. |
Chevys Kick A$$
Re: Tire/Lift ?
Yeah, that 9" of lift should be perfect. I got around 9"-10" of suspension and body lift on my '79 and it clears the tires perfectly.
-Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
