06-17-2006, 08:11 PM | #1 |
Accelerator cable for TPI
Was wondering if anybody could tell me what you are using for a accelerator cable for a 350 chevy tpi system. I have a 1970 c10 4x4. Thanks in advance Bill
06-17-2006, 09:25 PM | #2 |
Re: Accelerator cable for TPI
Try using 71-72 throttle it is a cable not a rod, thats what I am going to use. It take a little work to adapt it but what doesn't.
http://67-72chevytrucks.com/vboard/s...hreadid=100644 http://67-72chevytrucks.com/vboard/s....php?p=1383300
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
06-17-2006, 10:28 PM | #3 |
I used the factory camaro throttle cable and just cut a square hole in the firewall to mount the cable itself.
I also used a 71-72 gas pedal as it had the right end on it for the camaro throttle cable. I'll post some pics if you need more info.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
06-17-2006, 11:13 PM | #4 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I used the Camaro throttle cable as well.
It is a little long but it doesn't affect anything,a little unsightly if anything. Here's a shot of it...see how it sticks up. Or you can go the custom route and get one from Lokar. http://www.lokar.com/interior_pages/tc_kd.htm
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
06-17-2006, 11:55 PM | #5 |
Keep On Truckin'
Lokar all the way baby....
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
06-18-2006, 10:17 AM | #6 | |
Was it easy to install? How much,if any,mods did you have to make for it to work with our year trucks? Lastly,do you have the exact part# for it.
06-18-2006, 10:27 AM | #7 | |
Keep On Truckin'
Very easy to install, no mods and hooked up to stock gas pedal. I can't find my receipt but after looking at the Lokar website I think it is 1000HT.
06-18-2006, 07:52 AM | #8 |
Looks like I need to find a different gas pedal. Any body got one?
06-18-2006, 10:24 AM | #9 | |
Keep On Truckin'
06-18-2006, 10:44 AM | #10 |
thanks for the information and if you find time a picture of the hook up to the pedal would be great
06-18-2006, 10:47 AM | #11 |
what year was the truck you use the lokar on all so ?
06-18-2006, 11:32 AM | #12 |
Cool...thanks.
06-18-2006, 07:13 PM | #13 |
Mocwan,
I picked up a 86 TPI from a vette and am looking for some 86 L98 heads. I am going to put it on top of a 67 327. What cam did you use in your motor? Is your motor a roller motor? I realy like the Lokar Throttle cable. JRB |
06-18-2006, 09:02 PM | #14 | |
Keep On Truckin'
06-18-2006, 09:22 PM | #15 |
Keep On Truckin'
Here are some Lokar throttle cable pictures on the TPI set up. I forgot that I actually ended up cutting the Lokar cable since it was too long.
06-18-2006, 11:19 PM | #16 |
Is the cable permanently attached to the end or is it in there with set screws?
Great pic's BTW,thanks.
06-19-2006, 04:58 PM | #17 | |
Keep On Truckin'
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... Last edited by mocwon; 06-19-2006 at 04:59 PM. |
06-18-2006, 11:51 PM | #18 |
I used a cable off an early Riviera, and cut the cable to fit.
This was on a 71 4x4.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
06-19-2006, 03:59 PM | #19 |
I used a stock camaro cable.
