06-18-2006, 09:52 AM | #1 |
4x4 front axel
what are you 4wd guys using to replace the axel slingers {deverters} on your inner axel shafts to keep the sand and muck out of the axel tubes. these were discontinued by GM 14 years ago and i havent been able to locate a seal or replacement part any ideas? its a danna 44 3/4 ton
common sense isn't so common anymore |
06-18-2006, 01:15 PM | #2 |
Having issues
Re: 4x4 front axel
I buy them from the parts house. http://www.partsamerica.com/ProductD...pe=914&ptset=A
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." |
06-18-2006, 02:40 PM | #3 |
Re: 4x4 front axel
I use old CV boots as seals. It seems to work marginally well. I do a lot of deep mud and water, and its the best fix I've come up with so far.
06-18-2006, 07:59 PM | #4 |
Re: 4x4 front axel
All of the parts are available through your Spicer dealer.
Tim |
06-21-2006, 12:38 AM | #5 |
Re: 4x4 front axel
how do you locate a Spicer dealer?
06-21-2006, 07:30 AM | #6 |
Re: 4x4 front axel
Most any shop that deals with medium and heavy duty truck drivelines sells Dana/Spicer stuff. There are also quite a few mail order and internet stores that sell this stuff. Randy's Ring and Pinion can probably sell you anything you need http://www.ring-pinion.com
Tim |
