Old 06-18-2006, 09:28 PM   #1
jake67c10
Front end question
Helooo out there.......
I need some opinions on the most economical way to convert my '67 over to front disc's. I've got connections in the junk yard parts world so don't hold any ideas back, and I'm a pretty handy fabricator. Thanx a bunch!
jake67c10 is offline   Reply With Quote
Old 06-19-2006, 12:27 AM   #2
ThatOneBlue67
I survived Dead Man's Curve.
ThatOneBlue67's Avatar
Re: Front end question
I think you can keep the suspension and steering setup, just gotta add those spindles and everything else. Also convert to five lug and add a brake booster. I've never done it, but I'm sure there's a thorough process on here somewhere. Try the SEARCH engine.
ThatOneBlue67 is offline   Reply With Quote
Old 06-19-2006, 08:19 AM   #3
13lazer
13lazers' blazers
13lazer's Avatar
i tried to upgrade from drums to disks on a '70 2wd blazer using '71 spindles, calipers...
***important detail***
the centerlink is different. centerlinks alone are not as readily available ala carte from 1971-up as you would think. complete front crossmembers after 1972 rotor to rotor are the best way to upgrade. when i redo my '70 front i am thinking about a 3/4 ton assy. this time. i have read that they are very close to a direct bolt in swap between 1963-1987?? i think?
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
Old 06-19-2006, 08:32 AM   #4
Joe67
67 is sold
I would think a 71-72 front crossmember swap, disc to disc would be a good way to go if you have access to the parts
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 06-19-2006, 08:53 AM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
I went to a yard and got EVERYTHING for $150 off of a '71 truck. Complete front cross memeber, all brake lines, power booster and MS, and steering box (non power though) If you go that route, don't forget the connecting rod for the power booster (the rod that attaches to the brake pedal) cause they're different for non power booster trucks. I then spent probably another $200 on new ball joints, tie rod ends, bushings, calipers, rotors, etc..... I bought all of these parts from advance/autozone, except I had to order new brake hoses from LMC. It was well worth the money, trucks rides and handles great now. Stops a heck of a lot better, and easier too.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-19-2006, 04:52 PM   #6
jake67c10
Smile Re: Front end question
Thanks for the info fellas. I'll look into the 71-72' components. I was looking at the kits sold by the numerous companys out there, but it seems to me that they just use mostly parts from later trucks anyway, that I could buy from NAPA or A.Z. etc.. And the kits are pretty pricey. Oh well, we'll see.
Old 06-19-2006, 04:59 PM   #7
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
You can even use a complete crossmember (spindle to spindle) from 73-87. You just need to drill one hole on each side (in the frame IIRC).
Or, you can replace the spindles with drop spindles. Then go to the parts store and get 71 and up rotors and calipers. Or you can get the calipers from the boneyard and rebuild them.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-19-2006, 06:24 PM   #8
jake67c10
Thumbs up Re: Front end question
I just bid on a set of spindles, discs, calipers and related hardware on e-bay. 99 bucks for the whole set-up seems like a pretty good deal... we'll see. My buddy has a 84 parts truck I might be able to steal the front out of if need be. You say theres only two holes to drill? I guess the cross member dimensions are the same? Hmm interesting...
Old 06-19-2006, 06:29 PM   #9
Aarons72s
If I remember right you need the center link out of a chevy van. I dont remember what years will work. A friend told me he used one once.
Aarons72s is offline   Reply With Quote
