C10 Club Tennessee
Help with wiring up my new Taurus Electric Fan
I got this fan last week at the junkyard and was wanting some help wiring it up. I'd like the fan to run when the truck is running. Can you guys help me with this. I'm assuming that I'll need a basic Bosch relay for the job and a fusible link.
I believe it is the two speed fan which I'm sure will complicate things. Tim240Z gave me, but I'm too stupid to make any sense out of them. It appears that there are 3 wires coming out of the fan. I assume one is the ground and the other two are for High and Low Speed on the Fan. Thanks
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 06-19-2006 at 12:11 AM. |
Turbo Guy
Re: Help with wiring up my new Taurus Electric Fan
I have actually done this retrofit on my friend's 67 stepside, i'll try to get some pics. Yes it is a two speed setup one wire is ground I believe it is the all black one the other two wires one is for low speed and the other is high speed. If memory serves the two wires for the + are actually a different guage, the heavier being the faster one, which I would recomend. We hooked his up thru an aftermarket thermostatic control which i would also recomend. The control was cheap about 50 bucks. The only hitch to this is that the high speed wire draws somewhere in the neighborhood of 25 or 26 amps. To avoid the head scratching like i did at first when you keep blowing the 20 amp fuse in the thermostatic relay use a 30 amp relay to power the fan and switch on the relay with the thermostatic control. I found the fan fit extremely well, i just made some mounts to bolt it to the the shroud mounts. I read in an s10 conversion book this fan pulls the most cfm of any oem fan so it's a good choice, sorry to go on so long but i hope this helps.
C10 Club Tennessee
Anybodyelse? I just want this fan to basically come on when the truck is running and stay on. I'm not going to run it through the thermostat or anything like that. I did the great Headlight Relay over in the FAQ's but I need details on how to rig it up.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 06-19-2006 at 11:00 AM. |
Professional Grade
Why would you want to waste that much energy on keeping the the fan running all the time? As mentioned, they draw like 25+ amps while just running on high speed. I've got electric fans in my 89, and they rarely come on, only if you are sitting in traffic for an extended period of time.
It is well worth the money to buy a temp sensor to install on your intake, thermostat cover, head, or even a probe for the radiator!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
I agree with Russell. My electric fan rarely comes on, and it would be a lot of draw and wear and tear.
Here is the best writeup I have seen yet...
http://www.fordmuscle.com/archives/2...cfan/index.php I've been gathering info and parts to do this to a Jeep. Google searches have revealed a wealth of experience on this modification. |
laying low
![]() Join Date: Mar 2001
Hey what diameter is that fan? I like the looks of it. Does GM use any fans similar to this one on anything? I know they use the dual fans but what about single large diameter ones? And what year Taurus did that one come off of? thanks.
Ooh. I see Uncle T has posted a link to some good info on this.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 06-19-2006 at 12:48 PM. |
Global warming is a myth
search
There are several ways to do it, but I'd recommend using a Temp sensor, & a man. override switch so you can turn it on & off when or if you need it. Maybe it adds too much complexity for you're situation, but I like the idea of having control over that fan if I need it. Also, you should definitely use a HD relay because those fans draw a LOT of power @ start-up (around 100 amps, I believe). Later, Buddy Edit: great link UncleT!!
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's Last edited by BUDDY; 06-19-2006 at 12:33 PM. |
Here is another good read from some Jag owners looking to stay cool...
http://www.jag-lovers.com/books/xj-s/19-Coolmods.html |
No,I DON'T have Tourett's
ttt
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
C10 Club Tennessee
ttt
still want to wire this thing up just to run all the time. I know it doesn't make since but that's the way I want it. Hell, the fan cost me $11 at the yard so it's not like I can't go get another one. I also only drive me truck once a week if that.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
Apache Club
pm sent
![]() ![]() My Trucks Apache Sitting Idle MySpace Project Dad's Truck (74 C-10 to K-10 conversion) ![]() |
