Old 06-19-2006, 09:33 AM   #1
hd78glide
hd78glide's Avatar
67 GMC on 92 Chevy frame
I have a chance to get a 92 Chevy K2500 with a 6.5 diesel AT. Other than changing/moving the body mounts, does anyone have any "gotcha" info? Are there any major issues to deal with? How does the wheelbase match up? I've been searching the net for day's looking for the wheelbase for a 92 Chevy lwb regular cab.
Thanks...Jim
1967 GMC 1/2 ton
1972 GMC Sierra
1975 Chev 5/4 ton
1978 1/2 Harley FLH
1998 K1500 diesel
hd78glide is offline   Reply With Quote
Old 06-19-2006, 09:41 AM   #2
krue
Designated A-hole!
krue's Avatar
Re: 67 GMC on 92 Chevy frame
I've got a swb frame of about the same year and the frame looks nothing like the early truck frames, gonna take quite a bit of fabbing to make it work. If you do it, take a lot of notes and pics and write a FAQ for us.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-19-2006, 09:42 AM   #3
fine 67
Junior Member
it's alot of work and fabing. i put my 67 shortbox on a 95 4x4 frame .have been work on it for 2 yrs. good luck
fine 67 is offline   Reply With Quote
Old 06-19-2006, 11:38 AM   #4
hd78glide
hd78glide's Avatar
I've never done this before, other than the body mounts, what kind of fabbing is required?
1967 GMC 1/2 ton
1972 GMC Sierra
1975 Chev 5/4 ton
1978 1/2 Harley FLH
1998 K1500 diesel
Old 06-19-2006, 03:37 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
To make up for a non flat freame, you can make your own lift kit to level out the body.
I can't remember the screen name, a dude here put a 68 cab that he turned into an extended cab and made flairs for the fleet bed, then installed it all on a 91 or so daulie.
Old 06-19-2006, 04:07 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
68gmcdually? Seems like an awuful lot of work when the new stuff (motor tranny etc) can be swapped onto a 67-72 frame. If you do it, good luck and take lots of pics to show us all!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-19-2006, 04:13 PM   #7
Longhorn Man
There are some advantages to a frame update. Yes, new stuff can be put on an old frame, but in 68gmcdually's case, he woulda had to streach the frame, and now he has much cheaper suspention parts, and a frame that hasn't been rotting for 35 years. Not to mention the new science that has gone into the metals that make them flex a little in one way (for a good ride) and not flex another way (maintian geomitry)
Old 06-19-2006, 04:22 PM   #8
hd78glide
hd78glide's Avatar
Yes I could put all that on a 2wd 67 frame, but wouldn't putting the 4wd components on the 67 be just as much, if not more work? I really don't know for sure. Like I said, I've never done this, but I'm sure I could handle it.
Jim
1967 GMC 1/2 ton
1972 GMC Sierra
1975 Chev 5/4 ton
1978 1/2 Harley FLH
1998 K1500 diesel
Old 06-19-2006, 05:00 PM   #9
Longhorn Man
If you can plan through the hurdles of the non flat frame, and then ensure the wheel base is the same, or can be made the same, IMO, that would be better than adapting all that stuff to an old frame, plus, the new onw would have torsion bar springs instead of the leafs which ride just a little rough.
Old 06-19-2006, 06:29 PM   #10
hd78glide
hd78glide's Avatar
Thanks for the info, I look forward to the challenge! Now I just have to get the donor.
1967 GMC 1/2 ton
1972 GMC Sierra
1975 Chev 5/4 ton
1978 1/2 Harley FLH
1998 K1500 diesel
Old 06-19-2006, 08:44 PM   #11
dwaite72lnghrn
Think ahead about the computer placement, wiring changes for the diesel glow plug, Hydro boost mounting, pedal changes, steering wheel shaft mating (unless you are using the new steering column then cut the dash to fit it). Take close measurements of the cab to front core support to make sure it will fit. Stuffing 2 batteries in with the new air cleaner. Shifter location.
Sounds like a fun project.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 06-19-2006, 09:24 PM   #12
Longhorn Man
I had forgotten about the diesel part of the equation.
Good points... plan out and research everything before you start cutting anything. It can be done, and even fairly easily, and it'll be a one of a kind when done.
Old 06-20-2006, 08:46 AM   #13
hd78glide
hd78glide's Avatar
The battery's are the only thing that I have decided on so far. I plan on using 2 of these if I can get that donor truck.
http://www.classicperform.com/tech_a...attery-Box.htm
1967 GMC 1/2 ton
1972 GMC Sierra
1975 Chev 5/4 ton
1978 1/2 Harley FLH
1998 K1500 diesel
Old 06-20-2006, 01:34 PM   #14
Karl Hoh
A little east of nowhere
If you have the room, I would strip everything out of the 67, remove the bumpers, build extension supports and lift it high enough to roll the 92 chassis under the 67, then you will see exactly what fabing/ body mount spacing that needs doing.
68 C10 250 4spd
69 C20 327 4spd
69 910 250 3spd
80 K10 350 4spd
76 C60 366 5spd school bus
"THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR"
Karl Hoh is offline   Reply With Quote
Old 06-22-2006, 07:56 PM   #15
hd78glide
hd78glide's Avatar
The search for a donor continues. When I pulled the dipstick on the 6.5, it was full of metal shavings.
1967 GMC 1/2 ton
1972 GMC Sierra
1975 Chev 5/4 ton
1978 1/2 Harley FLH
1998 K1500 diesel
Old 05-07-2008, 05:25 PM   #16
TommyB1962
Would like to see any pics of your conversion especially the front end. You to Fine 67.
TommyB1962 is offline   Reply With Quote
Old 05-07-2008, 05:27 PM   #17
TommyB1962
The thing is I'm about to start on the same project with a '92 K2500 6.5 TD
Old 05-07-2008, 07:55 PM   #18
Just so you'll know the 92 LWB is 131.5 for the wheel base, I think our years is 127 (I only own shorts).
It can be done, but to get the bed to sit right and all you are going to be chaopping the frame to account for the 3+ inches of wheelbase difference. I have given it though on the SWB side alot, but so far the work does not seem to justify what I want to do.
Old 05-08-2008, 09:02 AM   #19
TommyB1962
My initial plans are to locate the cab & front fenders with rad support, then think about a trailing arm in rear, that way I should be able to cut off excess frame at the back. I would have to crawl under some ones rumnnig truck to measure the axle height, height of forward trailing arm bolts etc. But it should work. My biggest concern right now is getting the front end and cab to sit low enough that it doesn't look like crap and that the trackwidth isn't to wide. Luckily I have an A&W just down the street where they have a hot rod show & shine once a week in the summer. I should be able to hook up with someone there to get the measurements(with the correct Quantity of beverages in hand).
