Old 06-19-2006, 09:49 AM   #1
Alvin
Never Done?
Alvin's Avatar
Best tools for cutting c-notch?
Other than a plasma cutter (left mine in my other pants), what do you guys recommend for cutting the frame for a c-notch?
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 06-19-2006, 10:22 AM   #2
Joe67
67 is sold
Re: Best tools for cutting c-notch?
sawzall
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 06-19-2006, 10:57 AM   #3
cdowns
cdowns's Avatar
i use a jigsaw with a bimetal fine tooth blade for that type of stuff
Old 06-19-2006, 10:58 AM   #4
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
^ + eleventy billion.
Sawzalls are great!
you could always use a gas torch too!
(but sawzall leaves a nice cut, not chunky slag that needs to be ground(like plasma and gas)
but I guess you'd want to grind anyways, if you're preping to weld it together
|M|
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
Old 06-19-2006, 01:08 PM   #5
Frizzle Fry
Frizzle Fry's Avatar
I've heard of guys using a hole-saw. Seems like it would be the perfect tool for a c-notch if you are using round tube.
Frizzle Fry is offline   Reply With Quote
Old 06-19-2006, 01:15 PM   #6
cdowns
cdowns's Avatar
problem with sawzall is cutting a nice even contoured rounded hole// can use a hole saw PITA tho to cut half holes
Old 06-19-2006, 01:23 PM   #7
Alvin
Never Done?
Alvin's Avatar
Guys, I appreciate the faith you all have in me but this c-notch will be a bolt-in. I can't weld... there I said it! Thanks for all the tips though. I might try the jigsaw out seeing as I own one of those already.
Old 06-19-2006, 01:31 PM   #8
71swb4x4
71swb4x4's Avatar
Oil the blade periodically while you are cutting and the jig saw should work fine for you.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-19-2006, 03:00 PM   #9
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
I just did mine yesterday. Here's what I did.....
First I scribed the line I was going to cut, then in the upper two corners I used my Unibit (step-bit) and drilled holes there. You want to keep the upper edges rounded to eliminate possibilities of spider cracking in the corners. Then, I broke out the sawzall and started at the bottom and made my cuts up to the holes I drilled. From there, I just used a cut-off wheel to cut the horizontal line between the 2 holes. Cutting for the notch is the easy part!! The PITA was all the rivets you need to get out. Some are hard to get to with the air chisel.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 06-19-2006, 08:29 PM   #10
Rokcrln
Rokcrln's Avatar
For the first several that I did all I used was a .040 thick cut off wheel on a 4.5" grinder. I also used this for cutting off teh riviot heads before beating them out with a single jack and a big drift. Works great but now I use a Plasma and when operated right their is no slag to grind off that is what is so nice about them
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
