06-19-2006, 02:53 PM | #1 |
twisted trans output shaft
Is this trans output shaft useable?
06-19-2006, 03:16 PM | #2 |
Re: twisted trans output shaft
you could use it for cracking open walnets and pecans
06-19-2006, 03:34 PM | #3 | |
Chevy truck addict
Or Skulls.... |
06-19-2006, 05:29 PM | #4 |
I wouldn't use it BUT... it might very well serve a number of years before failing. Unfortunately when it fails , and it will , the damage will be catastrophic and much more expensive than a proper repair now. By the way, it takes a hell of a lot of grunt to bend a shaft like that. Did you launch the truck hard on slicks or something ? JMHO, Dean
06-19-2006, 06:26 PM | #5 |
Man that took some serious torque to do that! What were you doing to do that?
06-19-2006, 07:17 PM | #6 |
20' Daredevil (Ret)
Technically, it is usable -- but it will not allow the front DS yoke to slide along it as it should. Result can be some DS binding when the suspension works, i.e. when you are going over bumps.
Many long years ago, I twisted the output shaft of a TH400 in my '69 El Camino. All it took was some 'power braking' (apply brakes enough to lock the fronts, nail the skinny pedal and light the rear tires) courtesy of a 396/375 BBC.
06-19-2006, 09:23 PM | #7 |
no dont take the chance of it get a new one safey this the number thing of importance
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
