Old 08-03-2002, 11:35 PM   #1
69C10Atl
Trying to stick with it
69C10Atl's Avatar
Oil pressure problem...
I was just looking over my notes on things my truck needs and remebered that before I started taking it apart I replaced the oil pan seal and oil pump. Then the first time I fired it up the oil pressure gauge went all the way past H. Does anybody know what could have caused this?
69C10Atl is offline   Reply With Quote
Old 08-04-2002, 12:23 AM   #2
bigvinnie
bigvinnie's Avatar
all I can think of is if it was a hi volume pump, the gauge will read higher than normal...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 08-04-2002, 12:45 AM   #3
68 with 350 TPI
68 with 350 TPI's Avatar
If it is a factory guage make sure that you got the right sending unit.
There were a few diffrent ones.
I remember a engine I did and I put on a low pressure sending unit and it went way past the high mark.
Got the right one and problem solved.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 08-04-2002, 01:10 AM   #4
mikep
Used to have a truck
mikep's Avatar
mine does that every time I start it. factory mechanical gauge with hi volume, hi pressure pump. It almost never drops below H unless I am at idle and at full temp. dont worry about it.
No truck :-(
mikep is offline   Reply With Quote
Old 08-04-2002, 01:14 AM   #5
racedvl
racedvl's Avatar
I would get a aftermarket guage and see what it says.
racedvl is offline   Reply With Quote
Old 08-04-2002, 11:25 AM   #6
6869704X4
When I took mine apart it said 60psi on it. Im assuming thats what the H mark would be. Easy to get above that with new tight bearings and a high vol/press pump.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 08-04-2002, 02:20 PM   #7
69C10Atl
69C10Atl's Avatar
I guess I won't worry to much about it. That is unless is starts shooting oil out where it shouldn't. Then again an aftermarket gauge may be my best option.
