Old 06-19-2006, 10:14 PM   #1
Lil Chevy Rider
Swapping a 1970 3/4 ton rear end
Right now I have a 1970 Chevy CST 3/4 ton pickup that had a 350 engine and I swapped it to a 1977 350 Monte Carlo engine and auto tranny. Right now I have a heavy duty 8-lug rear end and want to change it to a higher gear 5-lug rear end the easiest possible way that doesn't involve a lot of messing around like if theres one you can just bolt right in. If anybody knows what kind of rear end would go best or what it takes to do a rear end job, any advice or comments would be appreciated.
Lil Chevy Rider is offline   Reply With Quote
Old 06-19-2006, 10:24 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: Swapping a 1970 3/4 ton rear end
I don't know the answer to your question, but you came to the right place for it.
Welcome to the board from South Mississippi!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-19-2006, 11:33 PM   #3
Rod
Could be possible to find a dana 60 3/4 ton diff from this era..they had 3.54 ,4.10 or 4.56. gears possible for these year trucks. If you have the pumpkin with a salad bowl looking cover.....4.10 or 4.57...aftermarket 3.90 if you can find them.
Now if you go 12 bolt half ton diff..well, lots of options for ratios there.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 06-20-2006, 12:15 AM   #4
wibilly
wibilly's Avatar
look at the 71 and 72 1/2 ton 2wd i think they were 5 lug, somone please corect me if i'm wrong
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 06-20-2006, 12:26 AM   #5
Lil Chevy Rider
Thanks for the advice about swapping the rear end.
Old 06-20-2006, 06:15 AM   #6
69gmctowrig
If the spring perches are the same distance apart you can swap in an axle out of anything you want. easy as pie. even if they aren't the same it can be done, just ask how a ford axle fits in a jeep
69gmctowrig is offline   Reply With Quote
