Old 06-19-2006, 10:35 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Dash Removal Question
I got some time tomorrow and I want to change the dash bezel on my truck. I tried this a couple of weeks ago thinking it would be a snap. I found out it isn't a snap. My question is when you take all the screws off the front of the dash will it pull forward enough so I can undo the speedo, tach & gauges or do I have to ( and I am getting a little old for this ) crawl under the dash and unhook everything before I undo the front of the dash.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-19-2006, 10:51 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Dash Removal Question
Under dash boogie all the way.
Besides, you'll need to do this for the headlamp switch too.
Old 06-19-2006, 10:52 PM   #3
TugOwar
I can reach up behind the cluster with my left hand and unscrew the speedo cable. Then, with the bezel screws removed, you should be able to pull the cluster out a couple of inchs, barely enough, but enough to get a 5/16 wrench in to unscrew the oil pressure line. With that done you should have enough room to reach in and unplud the gauge harness, probably enough for both hands if necessary. I put mine back in reverse order.
Good luck and let us know how it goes.
TugOwar is offline   Reply With Quote
Old 06-19-2006, 11:33 PM   #4
byrd
Union Electrician
byrd's Avatar
Check the FAQ's as there is a good write up on this in there
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 06-20-2006, 01:06 AM   #5
HeavyD
HeavyD's Avatar
In my experience the oil pressure line was the biggest PITA to undo. Rest can be done by reaching arm up behind dash without having to get upside down in the cab or anything.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 06-20-2006, 11:55 AM   #6
farside847
farside847's Avatar
Yeah, vac and oil line are a PITA. I always remember to put a wrench right under the sholderblade when ever Im under there.....
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 06-20-2006, 01:22 PM   #7
Already Gone
Thanks for the responses guys.. I can reach up and under and get the headlite switch , its the rest that I'm not looking forward to.. You 'd think GM would have designed the dash better so you wouldn't have to dismantle it to change a bezel.. I'll let you know how I make out, I'll be trying this afternoon.
Old 06-20-2006, 01:30 PM   #8
Bob Moore
Much easier if you take the steering wheel off and drop the column down.
Good luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 06-20-2006, 04:28 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
farside, I do too.But I always have to make sure the wrench I put under my shoulderblade is the one I need.That's so I have to crawl out and do it all over again.A couple of times I have even been able to have the wrench get under the same shoulder again before I could complete the job.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-20-2006, 08:04 PM   #10
byrd
Union Electrician
byrd's Avatar
bob moore has got it right, you should remove the little U shaped piece where the dash and steering column neet. You then can see a 1/2" or 9/16" bolt the hols the column up tight in there and you can remove the bolt to drop the column down about 2" to help with clearance. You should for sure drop the column down when trying to reinstall the dash with the new bezel on to help avoid any damage.
Zip:40272
Old 06-30-2006, 09:41 AM   #11
xfsketch
72 fleetside longbed 350
I recently took by dash bezel out but I was just inspecting the wire harness. I took the screws out of the bezel and for the life of me couldnt figure out why the thing wouldnt come out. Then I saw the speedometer cable after I layed on the cab floor, I unscrewed it easily with left arm sitting on the seat.(laying on the cab floor is a PITA for real!) The idea of the wrench under your shoulder is a good one! I will use that one as well. A word of caution- Watch your wires arent jammed under the bezel when you mount the new one on. I know its hokey but I didnt see mine were b4 and I crimped the wires pretty good. They still work fine.
xfsketch is offline   Reply With Quote
