Old 06-19-2006, 10:41 PM   #1
Daubs
Daubs's Avatar
Fancy valve cover question...
I'm battling the kinked / leaky valve covers on my new crate 350 install. Been thinking of getting some fancy covers, either alum or some from GMPP. Please correct me if this is a stupid question, but do all valve covers come with the oil filler hole? Some state they have the PCV / breather holes, not much said about oil filler hole.
And if no oil filler hole, how the heck do you put oil in the engine? (I know my Dad's old '62 Impala had an oil filler neck on the intake...but my Edelbrock alum intake does not). Help me understand this?
And suggestions on new covers would be nice also.
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 06-19-2006, 10:50 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Fancy valve cover question...
in all reality, all you need is the PCV hole, and the breather. You can unplug one of them and dump oil in through that hole.
Old 06-19-2006, 11:41 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Longhorn is right. But I will add that the pcv hole and the breather hole need to be on opposite sides of the engine. Meaning you need one hole in each cover. If the cast covers have no holes, the usually have a hole location cast on the inside. With a hole saw and the correct grommet you're good to go. Also, they should come with a baffle to screw in behind the hole, keeps oil from splashing or getting sucked out.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-20-2006, 12:11 AM   #4
Daubs
Daubs's Avatar
Thanks Longhorn & Fred. Always answers for my crazy questions on this site. I learn tons of stuff here!
I'm betting it takes a while to pour 5 quarts in the little PCV/breather hole with a baffle behind it...
Old 06-20-2006, 05:11 AM   #5
Longhorn Man
good call fred.
