Old 06-20-2006, 12:17 AM   #1
tom71
what happened to flint mi
tom71's Avatar
driveabilty problem
well the blazer i just bought drives really well on the surface streets , but when i get it on the freeway it starts to miss all over the place at a bout 45 to 50 mph i checked the firing order and put in a new cap and rotor it has been converted to hei and from what i could tell the po put in a new wire from the dizzy to the ignition unfused could my problem be the vaccum advance ? ignition module ? any ideas would be great thanks..... tom
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 06-20-2006, 01:08 AM   #2
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
Re: driveabilty problem
First thing to check would probably be the fuel filter also a good idea to check the total advance and make sure it's not above around 38 degrees at 3000 rpm. If you don't have access to a dial back to zero timing light just unhook the vacuum advance and cap the port on the carb and drive it to see if it's better. Also look it over for vacuum leaks. If it doesn't change check the valve adjustment and make sure it doesn't have any tight valves. I had a problem with a 454 doing something similar and it was due to two valves being tight...not tight enough to be a problem at low rpm but seemingly tight enough to cause cylinders to drop at about 2800-3000 rpm range. It's hard to diagnose a problem via pc but these are things I would check first along with anything I might have missed suggested by other members. Hope you get it figured out.
Oldtruckfanatic is offline   Reply With Quote
Old 06-20-2006, 10:08 AM   #3
Jason915
I only would add one more thing check your charging system.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 06-21-2006, 05:48 AM   #4
vtblazer
vtblazer's Avatar
Good advise so far.
I'd be suspect of the plug wires themselves as well.
How do the plugs look?
If their not new, I'd go right through and replace both the spark plugs and the spark plug wires if it were me. Just my .02.
vtblazer is offline   Reply With Quote
Old 06-21-2006, 08:34 PM   #5
tom71
tom71's Avatar
man old truck fanatic was rite it was one of those in 5 dollar clear in line filters plugged solid thanks alot for all of the in put .
97 fiance mobile
Old 06-21-2006, 08:48 PM   #6
Oldtruckfanatic
Truck junkie
Glad you got it fixed
Old 06-22-2006, 01:32 AM   #7
tom71
tom71's Avatar
me too the thing screams now life is much better now
97 fiance mobile
