Old 08-04-2002, 12:07 AM   #1
too many
too many's Avatar
Unhappy heater / ac blower problem!!!
Help!!! Does anyone have an idea what to look for in my 72 4x4? A couple of weeks ago , while running the AC on high, the high speed on the blower quit working. I could smell that " burnt wire" smell from under the dash. I hooked up a blower switch from another heater control, and still no high speed. Where to go from here? Thanks
too many is offline   Reply With Quote
Old 08-04-2002, 12:35 AM   #2
Hutch
Hutch's Avatar
There is a high speed blower relay above the passenger cowl vent just behind the dash attached to the upper portion of the inside a/c box. It will have a three wire harness attached to it and a very important ground wire
It is alot easier to see with the glove box liner out.
I think that if this is your issue the fan will work on low medium and then on high it will still turn but more like low speed.
You might want to check the harness to your fan switch also as they are prone to melt and cause problems.
You may even have a fan motor problem, but I would check the above items first.
Good luck
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 08-04-2002, 12:37 AM   #3
snow man
Lightbulb i got it
roll the windows down and suffer like me
snow man is offline   Reply With Quote
Old 08-04-2002, 12:46 AM   #4
too many
too many's Avatar
Question All trucks didnt come with AC?
Thanks for the advice snow man ! I may try hutches advise first tho! Thanks
