hood hinge replacement
I have two newly powder coated hood hinges on there way to me. What is the best way to replace them with out getting every thing out of wack? Remove hood or not.
Any tips would be helpful
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Re: hood hinge replacement
no one?
Be careful and remove and install one hinge at a time. Mark where the old hinge is located with a marksalot or similar. You will need your shoulders to hold the hood while inserting the bolts to hand tight. Then you're home free.
thanks stope4 I will hopefully have one helper with me.
Make sure your helper is holding the hood at the cowl so it doesn't slip and hit it. Then you need to make sure it doesn't try to flip down in front and bend.
