Old 06-20-2006, 04:59 PM   #1
Outkast
'66 c-10 I wanna bag...
Hey everyone, I don't really post much on here but I have a question about my 1966 c-10 fleetside. Future project... I have a stock rolling chassis, and want to know what the best way to get as low to the ground on frame as possible.
It has a two trailing arms and a panhard bar.
I really want to build an entire frame setup to lay out all the way.
Anyway just looking for tips to a new guy on baggin my 66,
I have a custom 94 Impala on 22's also, under some construction at the moment.
Outkast is offline   Reply With Quote
Old 06-20-2006, 05:09 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: '66 c-10 I wanna bag...
You won't lay in the rear with bags in the stock location without Z'ing the frame and a big notch.
The front, I believe, will accept the later model front crossmember. 1" notch, 3" spindles, bags -You're on the ground.
Over simplified, I know but there's a lot of info here if you search around a little.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-20-2006, 08:15 PM   #3
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
I think you can lay in the back with trailing arms, just not in the stock location. But you will need blocks. In the front you will need to Z the frame. I Zd mine 3 inches but Im not finished yet. It should lay easily on 22s.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 06-20-2006, 09:15 PM   #4
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
ROCKER:
2.5" drop spindles
2" drop lowers
3" Z
12" notch
3" blocks
bags on top of rearend
shorter body mounts it will kill the pinch's.
super track bar
DOOR:
same as above with 4 3/4" bodydrop
plus moved the trailing arms in and put bags in front of the notch on bars.
to lay on 22"s also added new tube uppers and lowers up front.
Watts link
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 06-21-2006, 11:58 AM   #5
Outkast
Is there any way to 4 link it?
Im new to this and want a nice low setup. Im not against buying a setup..
Where can I get the front CA's and other parts for a 66 c10?
How do you build a one off custom frame like ValleyCustoms ? Thats what I really want.
Old 06-21-2006, 01:02 PM   #6
bagged69c10
I I back halved mine and installed a ***************** super-lift triangulated 4 link and Im in the process of Zing it 3".
1965 c-10 long bed
1993 Sierra x-cab
Old 06-21-2006, 02:11 PM   #7
fastbagged68
fastbagged68's Avatar
You can lay out on stock trailing and WITHOUT Zing your frame!!! Here are pics of my 63 suburban that lays out on stock crossmember with custom A-arms, stock trailing arms!!!!
I would recommend 4 linking it though....will make your life alot easier. Also you won't have to do a long notch to clear your trailing arms.
fastbagged68 is offline   Reply With Quote
Old 06-21-2006, 06:56 PM   #8
lvscott
i dont know from experience what it takes to get the rear on the ground. but, check out this thread http://67-72chevytrucks.com/vboard/s...d.php?t=201898 this is what i'll be using to get the front end on the ground. hope this helps
lvscott is offline   Reply With Quote
