Oil pressure gauge reducer nut...
It's the reducer nut that screws in the top of the back of the block that the oil pressure line weird azz compression nut screws into. I've been all over toting my oil pressure line around asking for it...no one says they have anything close???
I think the threads going in the block are 1/8" MPT and then this compression fitting goes inside. Dealer??? |
Re: Oil pressure gauge reducer nut...
I went to the dealer and they told me to look in some old wooden drawers in a corner of the parts room. I found 4 of them and they said to take them away for free as they no longer had any use for them. Try a dealer, maybe they will have them. Good Luck.
GEARHEAD
Go to the hardware store and get a compression fitting with 1/8" pipe threads. Should not be hard to get.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#4 | |
I have done that....but would like to have the original fitting if I can find it. |
GEARHEAD
Your next best bet then would be the bone yard. Good luck.
