GEARHEAD
Looking for a firewall grommet
I'm converting to a power brake set up. Remove old master cylinder and there is a cracked and worn grommet that goes over the rod between the M/C and brake pedal. The new booster is mounted away from the fire wall but there is no grommet. So does someone sell that grommet, cause I couldn't find it in the LMC catalog in the brake section. Maybe it's in a gasket and seal section. Anyway, if someone has them, please post it.
Thanks, HG
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
![]() Join Date: Mar 2000
Re: Looking for a firewall grommet
http://www.gmcpauls.com/brakes_2.htm
You'll find them listed as the first part on the above web page link. GMCPaul |
I've been looking for one of those, mine's trashed!
If you can't drive it park it! If you can't park it milk it! |
GEARHEAD
Thanks GMCPaul. I did find one after further looking.
HG
They are still available from GM.......part number 3759198
1997 GMC Sierra Ext 1965 Mustang |
