Old 06-20-2006, 11:42 PM   #1
big blue 72
frozen and stripped off shoulders on brake bleeder screw?
on the front pass. side. i cant get it to budge and dont wanna break it off.
how do i get it out?
big blue 72 is offline   Reply With Quote
Old 06-21-2006, 12:07 AM   #2
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
Re: frozen and stripped off shoulders on brake bleeder screw?
They usually won't break although thats not a garrantee. When I have frozen bleed screws (they always strip the hex) I use a small vise grip to break it loose and then just replace it. unfortunately you pretty much have to take your chances because heat is not really an option. You might be able to put a punch on the side of it and wrap it slightly, Since its a seated screw it might help free it up. Thats about all I can think of I hope you get it out.
Oldtruckfanatic is offline   Reply With Quote
Old 06-21-2006, 12:26 AM   #3
BUDDY
Global warming is a myth
BUDDY's Avatar
I tore mine up a few years back & had to take it off completely & use the torch to get it out. Turned out badly. Now that caliper is locked up & needs to be replaced. Wish I had something constructive to add.
Good luck,
Buddy
Henderson, NV
1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!!
1990 K5 with 37's
2003 Discovery SE7 - Wife's
BUDDY is offline   Reply With Quote
Old 06-21-2006, 12:40 AM   #4
tom71
what happened to flint mi
tom71's Avatar
there are sockets that have a sharp cutting thread in them i believe they go in the right hand (ibelieve )direction so when you turn the socket left to loosen they bite into the stripped bolt , thesework very well to remove stripped bolts and nuts there is two varieties there is one with many reverse threads , these are not as good as the ones with less (5 or so ) i would try to find one of these sockets small enough to work .
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 06-21-2006, 06:20 AM   #5
Blazerb61
I have those sockets they sell them at Sears They work GREAT well worth the money
Blazerb61 is offline   Reply With Quote
Old 06-21-2006, 07:18 AM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
heat it with a propane torch and hope for the best. Rebuilt calipers aren't that expensive at Auto Zone.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 06-21-2006, 07:49 AM   #7
mrein3
mrein3's Avatar
I used to work in a repair shop here in the salt belt. I personally busted many bleeder screws.
If you are REALLY lucky, it will come out with a vise grips after soaking it over night with a quality penetrating oil. Don't use heat. That will kill the caliper for sure. If you really don't want to throw the caliper away, and you break off the bleeder, try an easy out. But now you risk getting metal shavings in the caliper.
I would start getting prepared to buy a new caliper. If it was a rear wheel cylinder (or front on a front drum brake truck), I wouldn't even waste the time. A new one is what? $10? What does a rebuilt caliper cost? $20? What is your time worth?
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-21-2006, 07:53 AM   #8
cdowns
cdowns's Avatar
when i get to the point you're at i've found it's time and cost effective to just go to the auto parts store and buy new calipers or cylinders
Old 06-21-2006, 08:51 AM   #9
wolfthing2000
Use Gibbs Lubricating Oil
wolfthing2000 is offline   Reply With Quote
Old 06-21-2006, 09:45 AM   #10
faribran
PLEAZZZZ dont buy anything from Autozone..
bad news.
faribran is offline   Reply With Quote
Old 06-21-2006, 09:47 AM   #11
stingray72
Red Headed Step Child
stingray72's Avatar
I did this last weekend on my corvette. Vice Grips worked for me
"Dinner, the perfect break between work and drunk"
-Homer Simpson
stingray72 is offline   Reply With Quote
Old 06-21-2006, 10:43 AM   #12
OLDCHEV4X4
OLDCHEV4X4's Avatar
I never had a problem using a propane torch. It dosent get as hot as oxy acetalene.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 06-21-2006, 10:47 AM   #13
shelby987
shelby987's Avatar
Vise grips....if you are really strapped to get a good hold, tighted the screw just past where you can close it by hand, and use a set of channel locks to close it up.
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 06-21-2006, 10:54 AM   #14
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I agree. Those parts are cheap, my time is worth more.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-21-2006, 09:14 PM   #15
big blue 72
thanks gang, vise grips and heat took it out tonight in about 10 minutes. gravity bleeding as I type, (and drink celebratory beers)!!!!!!!!
Old 06-22-2006, 07:24 AM   #16
OLDCHEV4X4
OLDCHEV4X4's Avatar
good deal!
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 06-22-2006, 12:09 PM   #17
wolfthing2000
Gibbs!
