Old 06-21-2006, 04:50 PM   #1
shelby987
shelby987's Avatar
front flex brake lines?? Need direction
I have run the numbers on the calipers and on my new front axle, the front axle is off of an 85 4wd K20, but the calipers are apparently from a 72-78 2wd front axle, I need lines that are almost 24" long, I would rather not swap in calipers, I have already spent way to much on this swap.....any advice or parts numbers would be appreciated, will the 2wd lines work, how long are they, and what size is the fitting that attached to the hard lines?
Also, does anyone have any idea why someone might make this swap?
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 06-21-2006, 05:00 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: front flex brake lines?? Need direction
Just a "WAG" wild a$$ guess.Maybe they were trying to upgrade the axle for 4wheelin and used the original calipers to save a few$$$.You didn't say what this axle was on,but that's the guess I have.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-21-2006, 07:15 PM   #3
shelby987
shelby987's Avatar
The axle was under a jeep, its a corp 10 bolt, if it matters.
But really the issue I am trying to solve is does anyone know where I can get longer 2wd front flex brake lines. Will the connection to the frame be the same on a 2wd and a 4wd? Can anyone get me pics, or at least a general length of their 72 front flex lines.
Old 06-21-2006, 09:33 PM   #4
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
check with your parts store, they should have books with pics of ends and different lengths available
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 06-22-2006, 08:36 PM   #5
shelby987
shelby987's Avatar
I THINK I have solved the question at hand, I think the 2wd calipers were used so the PO could run 15" wheels (as it is, the calipers have been ground down for clearance).
Anyway, I finally got what I think are the correct lines (72-78 2wd brake lines) but The hard-line portion of the line wraps out toward the wheel, and I need it to bend in toward the frame, can I have these bent in the other direction? (clearance is ok, but the line is now 5" to short).
Old 06-23-2006, 01:15 AM   #6
wibilly
wibilly's Avatar
i just bougt new calipers for mine they were only 17.99 each but core was $20
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 06-24-2006, 11:48 AM   #7
Firefighter
Exclamation Re: front flex brake lines?? Need direction
There is a right and left hose, try swapping sides that will turn them in Wagner # is F80000 for Right side, F80004 for the left side
Yellville, Ar. USA
Old 06-24-2006, 01:35 PM   #8
PanelDeland
Another thought on the brake lines is 4X4 parts.They are a parst store for 4wd and carry lots of special brake lines for lifted trucks.There may be other 4 wheel drive specialist who do also depending on who is in your area.
