Old 06-21-2006, 09:04 PM   #1
thewishartkid
thewishartkid's Avatar
Rust above windshield inside cab
Is everone having problems with this or is it just me? How are you handling the problem? i know you can get replacment parts but welding this area could be tough! could change hole top!
KIDs in the front seat cause accidents,Accidents in the backseat cause KIDs! If it aint short,It aint Sh#t! I like El Caminos
thewishartkid is offline   Reply With Quote
Old 06-21-2006, 09:38 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Rust above windshield inside cab
Many ppl just junk the cab once that happens, but they did just start selling this item a few years ago.
The sealant in the drip rail on top gets dry and shrinks over time, seems to be more of an issue on south and western trucks. Then, it rains and get wet inside there. Then, once it starts to rust a little, the rust holds the water when it rains again, and it evolves into a real seriouse issue. Personally, I would have to inspect the whole thing inbetween the inner and outer cab roof before I'd go replacing that panel... it would suck to replace it and then drop thousands in paint and body, only to discover that the surrounding area was already rusting, and only pops through AFTER you've spent your life savings.
Old 06-21-2006, 09:46 PM   #3
71chevytruckguy
71chevytruckguy's Avatar
that cab on my 69, which is 67 cab, is rusted all the way across bout an 1" thick. i took a wire whell and cleanin out all the bondo for the po and painted it to match the rest of cab, can hardly tell its there. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 06-21-2006, 10:46 PM   #4
72 Cheyenne402
72 Cheyenne402's Avatar
I have the same problem at first it was devistating. (My truck is from Houston and salt gets in everything down there.) I found a 71 AC cab for a replacement. it is in a lot better shape. My 72 cab is rusting so bad around the windshield pull the rubber back a little and the rust falls out aroud the seal. I hated replacing it but it seemed to be the only logical desision.
1972 Cheyenne 402 LWB
2005 Silverado X-Cab 5.3L
2004 John Deere L120 20HP B&S
72 Cheyenne402 is offline   Reply With Quote
Old 06-22-2006, 06:25 AM   #5
Mudder
Mudder's Avatar
I believe Calvin told me a few weeks ago that they are making a replacement for that area or maybe even the whole inside roof.
Mudder is offline   Reply With Quote
Old 06-22-2006, 07:31 AM   #6
Rokcrln
Rokcrln's Avatar
Personaly if you replace the cab or just the bad area I would make sure you get a good rust product up in side their before repainting. I like to tip the cabs over and shoot por15 (or =) up the A-posts,thru the visor holes, light hole in the rear of the roof and up the B-posts as well. Just soak the roof area and the A & B posts with product to treat and seal all the metal and then clean out the drip rails and do the same out their. This should help give a life time of protection since the factory did nothing to help make these areas last. I had to replace my California cab because of way to much rust and when I fould a good solid replacement for it I built the Tip & Flip just so I could get into very area posible before spending $$$ on paint and labor only to have it happen again. People always think of rust treating other parts of their truck but this is one of the most over looked area on these things.
Kevin
LFD inc.
Rokcrln is offline   Reply With Quote
Old 06-22-2006, 09:52 AM   #7
1LoC10
Insert Title Here
1LoC10's Avatar
Heres some pics of mine
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 06-22-2006, 09:55 AM   #8
1LoC10
Insert Title Here
1LoC10's Avatar
I was going to get this from GMCPauls some time doen the line
BOBBY
_69 SWB_
Old 06-22-2006, 10:44 AM   #9
72 Cheyenne402
Hey is that a pic of my cab? your are missing the rust falling out like mine
Old 06-22-2006, 10:13 PM   #10
thewishartkid
A lot of the cabs seem to have the problem! Sad thing is lower part of my cab is in real good shape!shame, shame,shame!!
Old 06-22-2006, 11:13 PM   #11
1LoC10
Insert Title Here
1LoC10's Avatar
Thats mine.....everytime im done driving I pick a few rust chips of the passenger seat...lol
BOBBY
_69 SWB_
Old 06-22-2006, 11:43 PM   #12
Fred T
Cantankerous Geezer
Fred T's Avatar
Here's my writeup on installing the patch without welding.
http://www.myoldtruck.com/vboard/showthread.php?t=7009
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-22-2006, 11:44 PM   #13
bad68bowtie
On the college boy budget...
bad68bowtie's Avatar
Mine has the same issue, it's made sealing the windshield a pain. The rust on my cab isn't as bad as what 1LoC10 has shown but my windshield will leak in a massive downpour.
-'68 C10 short/step- 350/350
bad68bowtie is offline   Reply With Quote
Old 06-23-2006, 12:45 AM   #14
lukecp
Formerly yellow72custom
lukecp's Avatar
Mine has it not only there, but above the BACK window too...needless to say, it is junk.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 06-26-2006, 08:57 PM   #15
55chevy
Car Truck Bike Nut
55chevy's Avatar
Yup same problem on my 70 project and my parts 72, 70 even has it above the doors. Luckily, my 68 driver is pretty good. Havn't decided how to repair it yet, I can get a good roof section for $50, might as well chop the top if I'm gonna go to that much work.
Snow free Florida panhandle, don't miss Indiana winters
Temp in Suffolk Virginia, Sentenced 2 to 5 years LOL
68 shortfleet project
94 3500 TD dually
so many cars so little time
72 K2 CST 2WD Blazer
55chevy is offline   Reply With Quote
Old 06-27-2006, 12:43 AM   #16
wibilly
wibilly's Avatar
mine are all rusty onthe bottom sides but the roofs are stilll good
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 06-27-2006, 01:17 AM   #17
Steelawork'n
Just hang'n around
Steelawork'n's Avatar
I get a little water through mine when it rains. Has caused the floor to start rusting. I'm afraid to start fixing it. The project might be bigger than I am.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year.
Steelawork'n is offline   Reply With Quote
