Old 06-21-2006, 10:50 PM   #1
72 Cheyenne402
72 Cheyenne402's Avatar
What is the best rear gear for??
What is the best rear end gear for a 402 w/ a 400th transmission? right now i am running a 373 rear end gear ratio but I I am thinking of a 355 or 342 posi any Ideas? what would you go with with this setup?
1972 Cheyenne 402 LWB
2005 Silverado X-Cab 5.3L
2004 John Deere L120 20HP B&S
72 Cheyenne402 is offline   Reply With Quote
Old 06-21-2006, 11:09 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: What is the best rear gear for??
depends on what you want out of the truck, and if the engine is built up or not.
Old 06-22-2006, 08:20 AM   #3
68Stepbed
68Stepbed's Avatar
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 06-22-2006, 09:31 AM   #4
72 Cheyenne402
The engine was built about 5 years ago Crane Fast bleed lifters - low end rv cam - 427 crank (because I couldn't find a 396 crank) - Crane chromollly pushrods - Crane steel stamped rockers - bored 40 thousands over (if I remember correctly) - High dome pistons - The heads were reworked with new valve job, valves, and valve seats for unleaded fuel. I thing reworking the heads costed almostr as much as rebuilding the engine. I almost bought some new BB aluminum heads.- Aluminum intake and AFB 750 carb- 3" 3 chamber flow masters 3" exaust all the way back to 4" tips.
Any Ideas?? I am still leaning to the 355 posi. This truck is a crusier anymore and the engine is not ratical just a good build
Old 06-22-2006, 10:01 AM   #5
BUDDY
Global warming is a myth
BUDDY's Avatar
Wink Re: What is the best rear gear for??
That seems like a pretty good combination to me. If you're looking for a little better mileage out of it, you might consider swapping the TH400 out for a Th700R4. For that mild BBC the 700r4 is plenty strong enough, plus it has a lower first gear, (for a little more kick off the line), & the added benefit of OD for those jaunts on the highway.
Swapping the gears would definitely be cheaper, but you could always do that or the trans swap afterward.
For me, I'd swap in a t-56 6-speed from a camaro or corvette. I like to row my own gears.
Later,
Buddy
Henderson, NV
1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!!
1990 K5 with 37's
2003 Discovery SE7 - Wife's
BUDDY is offline   Reply With Quote
Old 06-22-2006, 01:47 PM   #6
68Stepbed
68Stepbed's Avatar
I don't think you can get 3.55 gears if it's a truck 12-bolt. 3.42 is the only choice, which will work well also. Do you know what kind of rearend you have? The OD tranny is a good idea if you want to spend the money. If you want to get by on a budget, put a set of 3.42's in it.
Matt
Old 06-22-2006, 02:59 PM   #7
Longhorn Man
that sucker should have plenty of grunt. Myself, i'd say screw the overdrive, and just go with a 3.08 gear. You'll ned up with a good cruise RPM, maybe a couple hundred revs more than wanted, but not much, and the low end torque should walk right over that gear. Plus, this would be WAY cheaper, and more reliable than any GM overdrive with the exception of the 4L80E, but the cost of that swap would be as much as your motor was.
Old 06-22-2006, 03:24 PM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
AND you're more likely to find a 3.08 than a 3.42. 3.42's were rare for these trucks right? If you can find a good 3.08 you can swap the whole axle directly (as long as its a leaf rear with a lear rear or a coil rear with a coil rear, otherwise you'll have to swap the mounting blocks.) If you do decide to go OD I'd leave the 3.73 in the truck.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-22-2006, 04:29 PM   #9
BrianJordan
Iron Thunder
BrianJordan's Avatar
i like 411s,350/th350
BrianJordan is offline   Reply With Quote
Old 06-22-2006, 05:05 PM   #10
72 Cheyenne402
I had a 3.08 posi in it stock the gear just wore out so I went with the 3.73 which cam from another 72 truck it works well and will nearly throw your head through the rear window. I just run hi rmp's at 70-75 MPH. I'm thinking a different gear may help out. I don't want to lose any power or off the line speed???
Old 06-22-2006, 05:15 PM   #11
crazy longhorn
Fabricate till you "puke"
I like a mid 3's gear with a BB or big inch sb.......that said, I agree with Andy, that sucker will pull a 3.08 just fine . The swap from 3.73, to 3.42 is not worth the trouble(not enough change in rpms) on the hyway. If you change tire height, you can probably make up the diff in rpms tween 3.42 & 3.73....... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-22-2006, 05:20 PM   #12
Longhorn Man
3.42 was never found in these trucks, so there would be no simple axle swap.
I can't believe I said 3.08.... and no one jumped on me for it. (I always tell ppl it's not 3.08, ot's a 3.07)
Old 06-22-2006, 05:20 PM   #13
72 Cheyenne402
Right now I am running 15x10 with 295-50-15 on the rear and a 15x8 265-60-15 in the front I have been looking at moving up to a 17x10 on the rear with 285-40-17 and on the front 17x8 with a 245-40-17. I'd like to see how this combination works out. Maybe going with a bigger wheel could make all the difference
Old 06-22-2006, 05:29 PM   #14
67ChevyRedneck
I can't ever remember which is the correct one (3.07 or 3.08), I'm lysdexic so it don't matter anyways! I was shown a book at a junkyard with rear axle codes for 67-72 chevy trucks and some of the listings I remember were 3.07, 3.42, 3.73, 4.11, and 4.56. Maybe the 3.42 was used in vans or something? Maybe I was looking at the wrong years, maybe it was for a car? I just remember thinking, "man! if I could get a 3.42 with my 700R4 that would be awesome!"
Yup, larger diameter tires (overall larger height) will effectively give you a higher gear ratio. There's lots of online calculators out there, just google it and find one that uses a 1:1 ratio or you can find one and play with the tire/gear/OD ratios (a 700R4 uses a .70)
Jesse James
Project "On a Dime"
Old 06-22-2006, 05:46 PM   #15
Longhorn Man
3.07 is correct.
The 3.42 wasn't offered, not as a RPO anyways. I'm sure it was used in cars, and maybe vans, but I know for ertian it was not an RPO on the 67 - 72 10 - 30 trucks.
Old 06-22-2006, 05:49 PM   #16
I agree with Andy. With a BB get the 3.07 or 3.08. Unless this is being used as a serious work/pulling/racing truck, that will give you the best overall driving ratio.
Old 06-22-2006, 05:51 PM   #17
crazy longhorn
The 3.42 gears are available aftermarket (Richmond, ect). The 75 12 bolt under my truck actually has e 3.40 gear..... L
Old 06-22-2006, 06:08 PM   #18
stope4
Longhorn Man
When you do the calculation isn't it something like 3.07692307692. It's so close I think you can get away with either 3.07 or 3.08.
stope4 is offline   Reply With Quote
Old 06-22-2006, 06:32 PM   #19
jsbgump
Gone Fishing
jsbgump's Avatar
With that setup I would run 3.08's
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 06-22-2006, 09:03 PM   #20
Longhorn Man
There was a reason for the 3.07 and the 3.08 gears. The 12 bolt in our truck is not the same as the 12 bolt for a car. This way, back in the day, there was no confusion when a tach ordered gears. If he ordered 3.07...it was a truck, if he ordered 3.08, then it was a car.
Old 06-23-2006, 12:42 AM   #21
409biscayne
409biscayne's Avatar
I love my 3.73's in my 68 bb t400 c10 . I like being able to outrun the new trucks , at least stoplight to stoplight . Especially those v8 ricer wannabe's .
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 06-23-2006, 01:25 AM   #22
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
I went with 3.54 for the Dana rear , it works out great for city and freeway driving .
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 06-23-2006, 09:06 AM   #23
72 Cheyenne402
I think I may just go with some bigger wheels maybe some 17" or 18" and see how that works out. I planed on going bigger on the wheels anyway. Can't beat that 3.73/400 trans/402 from one stoplight to the next. I used to take the old 5.0L Mustang's in Houston. You should have seen the anger on there faces. it was great!!
Old 06-23-2006, 07:05 PM   #24
68Stepbed
68Stepbed's Avatar
The 275/40/17 tires won't help you. They are actually a smaller diameter tire. The 295/50/15's are 26.6" tall. The 275/40/17's are 25.7" tall. It would actually be like going to a lower gear and higher revs. If you go with a 275/50/17 or 275/55/17, that would help a little. The 3.42 gears would still work well, a good mix between good off-the-line acceleration and still turn lower rpms at highway speeds.
Matt
Old 06-23-2006, 09:20 PM   #25
mbgmike
yeah no 3.55 3.42 is closest gm #12-342 for truck 12 bolt. Also it helps to know your tire diameter
mbgmike is offline   Reply With Quote
