DFW area parts needed:
I still need a few things to complete the V8/auto swap into my Beater. I need:
t350 yoke SBC fan shroud stock style (clutch) fan Anyone have something local in the Dallas area?
71 GMC 454/TH400
Re: DFW area parts needed:
Have a TH350 yoke, $25
"The bigger you are the harder you fall, the farther you walk the longer you crawl." |
![]() Join Date: Aug 2004
Hey man,
I have a non-thermo fan clutch (but no fan blades). $10 Clay
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
There's a swap meet this weekend at LaGrave field here in Ft Worth.(Just in case you didn't know
scoti i may have the stuff you need i'll check and let you know ps the 396 is good to go machine shop guy sais it was a realy low milage block cylinders didn't even have ridges wore into them yet line honed and new bearings.
I got what I needed from 2 board members today @ the Ft.Worth swap meet.
Thanks Matt & Shane!
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-24-2006 at 11:24 PM. |
