Old 06-22-2006, 01:15 AM   #1
rapidride3
10 bolt or 12 bolt
Hello I might be in the process of purchasing a 1/2 ton, 2 wheel drive, long bed, 76' chevy cheyenne, 350 ci,,th-350 automatic. The trucks drive train has not been changed. I have not been able to view the truck as of yet. My question is,,,, Did these 76' trucks come with 10 and 12 bolts??? or just 12 bolts??? If so what were the available gear ratios for the 1/2 ton 2 wheel drives???? thanks.
rapidride3 is offline   Reply With Quote
Old 06-22-2006, 05:32 AM   #2
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Re: 10 bolt or 12 bolt
The truck should have a 12 bolt in it. They did not start 10 bolt rear until around 1981. The most common ratio to have is 3.73's but could come with 3.08 or 4.10 ratios also.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Old 06-22-2006, 10:42 AM   #3
cliffsta
Stepsides RULE
cliffsta's Avatar
Well, they started putting the 10 bolt in SOME trucks in the late 70s, but by 81 the majority went to the 10 bolt.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 06-22-2006, 02:15 PM   #4
rapidride3
Thanks,,, i will assume before seeing the truck that it should have a 12-bolt. i will check the codes and see if it has a lim. slip and hopefully for me,,, a 3.73.
