Turbo 350 to 700r4 conversion
Hey guys, can anyone tell me....if I install a 700r4 in my 71 GMC, will the existing three speed auto shift on the column work? Will it not drop all the way down in first or will there be other problems I haven't thought of? Thanks for any help.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
Re: Turbo 350 to 700r4 conversion
I had a 3 on the tree column and I was told I need to change it to and auto column...so I did! My set-up 350 engine 700r4 Trans
huh ???
I have a 700r in my 72 that originally had a th350. On mine you can't manually pull it into 1st but I have a tilt column. I'm not sure with a non tilt...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
That was my concern CustomCamper. I was hoping you would of said it had enough travel to operate a 4 speed. I don't suppose it's a big deal, but knowing I can't shift to 1st will bother me. I don't suppose there are any modifications that can be done, don't really want a floor shift as my wife thinks the "passenger" sits in the middle.
