Old 06-22-2006, 08:23 PM   #1
tom71
what happened to flint mi
tom71's Avatar
hei stock tach ,how far off is the reading?
does any body know how to make a factory tach work accurately with a hei? how far off is it ? any one ? any one??
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 06-22-2006, 08:44 PM   #2
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
Re: hei stock tach ,how far off is the reading?
There are a few places that will set up your tach to work with the HEI. I don't know how far off it is I have just read a bunch of posts on the subject on other sites. I have always wondered if a guy could wire in a radio shack potentiometer (adjustable resistor) and a temporary tach and adjust the potentiometer to match the factory tach to the temp tach. I have no clue if this can be done just something I have wondered.
Oldtruckfanatic is offline   Reply With Quote
Old 06-22-2006, 08:46 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it should read fine...assuming your 35 year old tach is acurate.
A tach is a tach, doesn't matter if you have points or HEI.
Old 06-22-2006, 08:48 PM   #4
barepaint
barepaint's Avatar
longhorn is right just plug and play...just did it a month ago
barepaint is offline   Reply With Quote
Old 06-22-2006, 10:20 PM   #5
byrd
Union Electrician
byrd's Avatar
Yep, all the repopers say their tachs won't work with HEI and I have personally tested well over 150 repop tachs and all have worked fine with HEI. I think the tachs are accurate enough but not perfect,and I haven't had the chance to hook two up at the same time to check them against a factory tach or another type of tach for that matter.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 06-22-2006, 10:26 PM   #6
Bob B.
Don't know that HEI would cause a problem with either an original tach. or a reproduction, but an MSD or any other multiple spark discharge ignition will.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 06-22-2006, 11:37 PM   #7
Blue85
Oilfield Trash
Blue85's Avatar
So is their anyway to make it work an msd style ignition?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 06-23-2006, 12:33 AM   #8
tom71
tom71's Avatar
well a while ago i asked a speedo shop about it and they said they would have to make a" special " harness to work with the hei and the factory tach . is this special harness nothing more than a plug for the tach and a plug for the hei batt and tach (like the plug i nabbed today at the bone yard ??)oh and the speedo place said they would charge me "only 125 dollars " geee thanks for nuthin !
97 fiance mobile
Old 06-23-2006, 12:59 AM   #9
wibilly
wibilly's Avatar
so do the factory tachs last wired to a hei? i thought i read a post awhile back on here that they would not last without burning out but i don't know why but then again i know very little about electronics
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 06-23-2006, 01:16 AM   #10
Richard
I had always thought the pot that is accessable from the back of the tach is for adjustments Never messed with it though.
Richard
Old 06-23-2006, 06:09 AM   #11
byrd
Union Electrician
byrd's Avatar
Richard you are right, you can calibrate them some.
Zip:40272
Old 06-23-2006, 10:53 AM   #12
StingRay
StingRay's Avatar
I have run my stock oe factory tach with hei and msd. No problems. I checked it against a tach in my digital volt meter and while it was not killer accurate it wasn't more than a couple hundred rpm out in it's worst case. I have about 10 years of straight hei to fact tach with no problems and about 3 years of msd to factory tach with no problems. I believe that adjustment pot on the back is used to set the tach to zero isn't it?
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 07-04-2006, 12:16 PM   #13
Madbomber88
Active Member
Madbomber88's Avatar
Not sure if this helps, but my factory tach with HEI reads 400 RPM faster than it really is.
71 Blazer CST
72 K20
Capt USAF
Madbomber88 is offline   Reply With Quote
Old 07-04-2006, 12:19 PM   #14
byrd
Union Electrician
byrd's Avatar
they you reach around to the back of the dash with a small flat head or phillips I can't remeber which one and turn the little screw in the back of the tach until you get the right reading. This is how they are calibrated
Zip:40272
