Old 06-23-2006, 09:23 AM   #1
Custom 68
Custom 68's Avatar
side window outside bottom seal? and 1 piece windows
Hey all, I have been plagued with my "wipper" seal or what ever it is called on my truck for ever. The bottom rubber seal does not seal against the window. I have 2 and they are both the same even with new seals. Is this common?
I am planning or hopping to go to 1 piece windows is this seal better? Is it like the new trucks that actually "folds" up on the lower window? I just cant seem to get away from my wind noise so I am hopping the 1 piece will cure that?
any pictures would help...
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 06-23-2006, 09:56 AM   #2
ChevyDude
Re: side window outside bottom seal? and 1 piece windows
I have ridden in a truck with one piece windows from Brothers. Very quiet. I had the same problem with new vent windows I bought...they fit terribly with huge gaps and the bottom. My one peice windows are awaiting Brothers to ship them to me, they are backordered.
ChevyDude is offline   Reply With Quote
Old 06-23-2006, 01:00 PM   #3
greasemonkey
greasemonkey's Avatar
Custom 68, there is a bracket under the vent window that comes welded from the factory. When it breaks, the door "spreads" apart and the rubber will not seal. When adding one piece windows, you cut this bracket out altogether, and the rubber seals seal against the window.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 06-24-2006, 08:43 AM   #4
Custom 68
Custom 68's Avatar
thanks guys,yea during my resto i rewelded that piece and even squeezed the door together as much as possible with the vent windows.
anway I will continue on my quest
any other thoughts?
Dave
Dave
