Old 06-23-2006, 03:35 PM   #1
76bonanza
76bonanza's Avatar
classic heartbeat electric fan kit
Those that have installed this kit I am doing mine this weekend.
First question is the temp probe for the fan should go thru the rad close to the upper hose right.
Second questions the rubber grommets do they go between the fan and shroud or shroud and radiator.
Last question did you cut off the plugs from the fans or put spade connectors on wires and use plugs?
one more thing it says 20 amp fuses but the fuses in it look like 30 amps?
any other tips for this kit would be nice
ps were is a good place to mount a toggle overide switch?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 06-23-2006, 09:54 PM   #2
KEH
Better late than never
KEH's Avatar
Re: classic heartbeat electric fan kit
Sorry not to be of any help...let us know how it goes. I am considering this fan kit from WES also.
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 06-23-2006, 10:09 PM   #3
76bonanza
76bonanza's Avatar
think I got it
1968 c10
lowered 3" 4"
Old 06-23-2006, 11:06 PM   #4
76bonanza
76bonanza's Avatar
No back to not working It worked for about 10 minutes then the fans just started up for no reason. If I hook it up the way wes says the fans just run and run if I pull the ground under hood move the overide switch to the other end I can control them with the switch? Does it sound like the thermo is bad?
1968 c10
lowered 3" 4"
