Old 06-23-2006, 05:59 PM   #1
zipgun
ZIPGUN
zipgun's Avatar
Bad Brake Proportioning Valve???
Hi all,
My 90 Burb has been front braking really weird. I have never had a prop valve die on me so here goes. When the brakes are cool and during the first stops it does fine but after they are used awhile the front end seems to grab in each direction alternating grabs. I do not believe the rotors are warped (truck has 123,000 miles on it) and from what I can tell the caliper pistons seem to be operating alright. Anyone ever deal with this or experience the same symptoms ?
Thanks all,
Steve
zipgun is offline   Reply With Quote
Old 06-23-2006, 07:35 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Bad Brake Proportioning Valve???
Front brake hoses at the steel clip where they bolt to the arm some how swell or shrink and restrict the flow when hot. had this happen on my 92. changed everything down to the bearings never thinking a hose would be the cause.
dwcsr is offline   Reply With Quote
Old 06-28-2006, 07:17 PM   #3
zipgun
ZIPGUN
zipgun's Avatar
Hey DWCSR Thanks !!!! You were right on the money !! No more teeth chattering stops !! Thanks I appreciate the help.
Old 06-28-2006, 10:44 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
When it happened to me I was in hi speed traffic in a construction zone. Changed my shorts when i got home.
Old 07-09-2006, 09:59 AM   #5
zipgun
ZIPGUN
zipgun's Avatar
I drove from North Carolina to Washington DC for the fourth. Thing ran great until on the way back it started shuddering again. If I pump the brakes acouple times before mashing all the way down it wont shudder. Its got me stumped. Pulled into my driveway and the water pump popped the weep holes. Replaced that yesterday. I love this truck just wish i could figure out whats up with the front discs doing the boogie woogie braking.
Old 07-09-2006, 10:59 AM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
make sure the the pads are tight in the calipers. bend the pad tabs so they are against the housing tightly. it sounds like the pads are wobbling on the calipers
