Old 06-24-2006, 05:09 PM   #1
77pdxC-10
air bags
if you run an air bag setup should u use the stock spindles or run the dropped ones such as the DJM 3 inch drop spindles????
77pdxC-10 is offline   Reply With Quote
Old 06-24-2006, 06:40 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: air bags
What are you goals with airbags? If you want to ride it low when aired up, you have to lower it some sort of way.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-25-2006, 02:56 AM   #3
77pdxC-10
Re: air bags
so to get the slammed look with the bags inflated u'd still do the normal things such as drop spindles and shackle kits
Old 06-25-2006, 02:25 PM   #4
Captkaos
Captkaos's Avatar
Re: air bags
Yes that is correct. Airbags don't "lower" a truck, you are limited by the way you mount them, You can get about 3" of drop out of them, but that is about it by just installing airbags. If you want it low, you have to lower it some way. Airbags only lower it when they are deflated, and you can't drive it like that...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 07-06-2006, 04:41 AM   #5
Bagged87C10
Bagged87C10's Avatar
Re: air bags
i have early classic on mine... 2" with 20's lays out nicely,,,,,
Bagged87C10 is offline   Reply With Quote
