Old 06-24-2006, 10:50 PM   #1
rchdrm
The start of the $ pit!
rchdrm's Avatar
cracks in steering wheel
I've got another question I need help with.
I want to use the original steering wheel from the 68 but it has some crack in it. How do you repair these? Epoxy or bondo? Thanks for the help.
rchdrm is offline   Reply With Quote
Old 06-24-2006, 11:29 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: cracks in steering wheel
I think that por-15 makes kit to fix the cracks...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 06-25-2006, 01:35 AM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
This is not a good place to use bondo, it will crack. I haven't used the por-15 kit or seen the long term results. I have also not seen a repaired wheel that didn't crack again after a few years.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-25-2006, 08:54 AM   #4
Boog
laying low
Boog's Avatar
Seems like I remember Eastwood having a repair kit. I have seen epoxy used and body filler used but like was said they may crack again if sitting in the sun very much however it shouldn't be any more prone to cracking than any part of the outer body where filler is used. IMO
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-25-2006, 09:21 AM   #5
Brand new steering wheels crack in time,too.JBweld it,sand,and paint.Enjoy your original wheel a while longer.
Old 12-03-2010, 11:20 PM   #6
jondancer
so is it the metal that is cracking ?
jondancer is online now   Reply With Quote
Old 12-04-2010, 12:24 AM   #7
C. M. Wolf
C. M. Wolf's Avatar
I was helping a friend of mine do this very fix. The best results we found were using the "Fiber-Glass Bondo" repair material. This does require some painting afterwards and it can be some pretty messy stuff to work with, but it sticks very well and generally will only crack if lots of pressure, hot and cold variations get to it over time.
The cracks need to be opened up to a slight "V" so that the fiberglass resin mix can get fully to the steel in the wheel. This all needs to be clean and free of any old, flaking, chipping plastic and the steel needs to be free of any rust.
It may be simply easier to replace the wheel with a new 'stock' wheel, all the same.
IMHO
Michael
C. M. Wolf is offline   Reply With Quote
Old 12-04-2010, 12:39 AM   #8
LockDoc
The Older Generation
LockDoc's Avatar
There is a pretty good thread on this in the FAQ forum. Scroll down to the bottom of this page and you will see the "Forum Jump" box. Click on the little down arrow on the right side of the box and scroll down to "FAQ Truck Tech". It's down a ways. On that page go down to "Thread / Thread Starter: FAQ Index thread" and click on it. When you get into that scroll down to the "Interior Related FAQ's" section then find "Restore 67 Wheel".
I could have just posted a direct link but there is a lot of good info in the FAQ section and now the people that read this thread will know how to get to it.
Thanks to Krue for indexing the FAQ's
LockDoc
Leon
