06-25-2006, 05:26 AM | #1 |
Question on Brake ID
I own a 1983 Chevy C10 pickup with a 6.2 diesel and need to know how to ID the brake system that is in ita As right now I do not have any brakes that work. Every part store that I go to ask me what brake system I have. They say there is a tag in the engine compartment or on the glove box door that tells you. I can not find any tag or information anywhere that says which system I have. I do know that I have a Hydro Booster on it and so I am turning to you folks for help. Thank You in advance for the help. Scot
06-27-2006, 06:21 PM | #2 |
Re: Question on Brake ID
Anyone? Doesn't anyone know?
06-27-2006, 09:11 PM | #3 |
Sytar 69,
Most parts stores will go by the RPO code. It's on the glove box and for '87 anyway, begins with a "J". When I ordered brakes for my 1987, I just told them "1987 GMC 1500 4x4 with JB5 brakes" and they gave me exactly what I needed...they even gave me the jobber price just because I knew what I was talking about! Here are the RPO codes for GM Trucks...I think they pretty much cover all the years that style was built...but it should get you closer to an answer...you can always google "GM RPO CODES"... Hope these help... J1F : BRAKE PROVISION SPECIAL TO SUIT FOREIGN REGULATION J41 : BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON J42 : BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, ALUMINUM J50 : BRAKE SYSTEM, POWER J52 : FRONT DISC BRAKES J55 : BRAKE SYSTEM, HEAVY DUTY J56 : SPECIAL HEAVY DUTY BRAKE PACKAGE J61 : DRUM BRAKES J65 : BRAKE SYSTEM, PWR, FRT & RR DISC J81 : INDICATOR SWITCH, EXPORT J85 : BRAKE SYSTEM, PWR, FRT & RR DISC JA1 : BRAKE, LIGHT WEIGHT DISC DRUM JA2 : BRAKE, HEAVY WEIGHT DISC DRUM JA3 : BRAKE, SYSTEM, WAGON DISC DRUM JA4 : BRAKE, SYSTEM, PWR FRT DISC, RR DRUM, CAST IRON JA5 : BRAKE, SYSTEM, SPORT COUPE DISC DRUM JA6 : BRAKE, EXTRA LIGHT WEIGHT DISC DRUM JA7 : HANDLE, PARK BRAKE RELEASE, LEATHER JA8 : BRAKE, MEDIUM WEIGHT DISC DRUM JAF : BRAKE, PROVISIONS EUROPE JB1 : BRAKE, MANUAL, DISC/DRUM, 4300 LBS JB3 : BRAKE, POWER, DISC/DRUM, 4600 LBS JB5 : BRAKE, POWER, DISC/DRUM, 6400 LBS JB6 : BRAKE, POWER, DISC, DRUM 7200 LBS JB7 : BRAKE, POWER, DISC, DRUM 8400 L85 JB8 : 8RAKE, POWER, DISC, DRUM 10000 LBS JC4 : BRAKE, POWER, DISC, DRUM 5600 LBS JC5 : BRAKE, VAC POWER, 4-WHEEL DISC, 7200 LBS JC7 : BRAKE, POWER, DISC/DRUM, 12000 LBS JCB : BRAKE, POWER, DISC/DISC, 20000 LBS JD3 : BRAKE, HYD POWER, DISC/DRUM JD5 : BRAKE, DUAL POWER, DISC/DRUM, 6400 LBS JD6 : BRAKE, HYD POWER, DISC/DRUM, 7200 LBS JD7 : BRAKE, HYD POWER, DISC/DRUM, 8400 LBS JE1 : BRAKE, SYSTEM, EUROPE JE5 : BRAKE, SYSTEM, PWR, ANTILOCK, FRT & RR WHL JF9 : BRAKE, HYD POWER, 4 WHEEL DISC JG1 : SHAFT, PROP, ALUMINUM JH5 : BRAKE, HYD POWER, 4-WHEEL DISC, 7200 LBS JH6 : BRAKE, HYD POWER, 4-WHEEL DISC, 9900 LBS JL2 : BRAKE, FRT DISC, SINGLE PISTON JL4 : ACTICE HANDLING JL6 : BRAKE, SYSTEM, MAN, FRT DISC, RR DRUM, CAST IRON JL8 : FRONT & REAR DISC BRAKES JL9 : BRAKE, SYSTEM, PWR, FRT a RR OISC, ANTILOCK, FRT W JM3 : BOOSTER, BRAKE, 240MM TANDEM, HIGH FLOW JM4 : BRAKE, SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON, JM5 : BOOSTER, BRAKE, 200MM TANDEM, HIGH FLOW JM7 : BOOSTER, BRAKE HYD HI PERF, DELCO-MORAINE JM8 : BRAKE SYSTEM PWR, FRT DISC RR DRUM, ALUMINUM, |
06-27-2006, 09:42 PM | #4 |
Sierra, my problem is that I do not have the sticker anywhere on the truck. I looked in,on the glove box, and I looked everywhere in the engine compartment and nothing is there anywhere. Could the title or the VIN tell me anything? Scot
06-28-2006, 12:52 AM | #5 |
www.73-87chevytrucks.com
Pull the wheel off and measure the rotor. There are only 2 options. Standard (1" thick rotor) or Heavy Duty (1.25" rotor)
Being a Diesel with Hydroboost, I am betting it is HD...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
06-28-2006, 09:32 AM | #6 |
So would that be a JB5,JD3,JD5 or JB1 ,JB3. The first three are together on the part store web site and the other two are together, I think the first three are the heavy duty system. I am going to replace the whole system from front to back and need to figure out which system I have as I live 65 miles from the closest part store.
06-28-2006, 10:59 AM | #7 |
I found this chart to help with physical ID if the sticker is gone...
GM LIGHT-DUTY GM Light Duty Truck Brake Options: 1984 and later. Brake system replacement parts for GM light duty vehicles depends on which production option is installed on the truck. Either one of two methods can be used to determine which option applies: Method 1: The service parts identification label (SPIL) lists what options are on the truck. The physical location varies by series: - C, K, R, S, T, V Series: The SPIL is located on the inner surface of the glove compartment door or on the left front inner fender skirt. - G Series: Inner surface of the hood panel. - M Series: Inner surface of the glove compartment door. - P Series: Not adhered to the truck at the factory, but mailed to the dealer. If possible, contact dealer for placement. Method 2: Physical examination using the following specifications: Engine Front Rotor Rr Drum/Rotor Power Booster Production # Gas 11.86" x 1.28" 11 x 2" None JB1 Gas 11.86" x 1.28" 11 x 2" 9.5" Single Diaphragm JB3 Gas 11.86" x 1.28" 11.15" x 2.75" 9.5" x 8" Dual Diaphragm JB5 Gas 12.5" x 1.28" 11.15" x 2.75" 9.5" x 8" Dual Diaphragm JB6 Gas 12.5" x 1.28" 13" x 2.50" 9.5" x 8" Dual Diaphragm JB7 Gas & Diesel 12.5" x 1.53" 13" x 2.50" Hydro-boost JB8 Gas 14.25" x 1.53" 15" x 4" Hydro-boost JB9 Diesel 11.86" x 1.28" 11" x 2" Hydro-boost JD3 Diesel 11.86" x 1.28" 11.15" x 2.75" Hydro-boost JD5 Diesel 12.5" x 1.28" 11.15" x 2.75" Hydro-boost JD6 Diesel 12.5" x 1.28" 13" x 2.50" Hydro-boost JD7 Gas & Diesel 14.25" x 1.53" 13.75" x 1.53" Hydro-boost JF9 (4 wheel disc) Here's the link. Make the chart easier to read/print... http://www.arvinmeritor.com/tech_lib...tents_1-19.pdf |
06-28-2006, 06:17 PM | #8 |
Thanks, With the information that you all have given me I now can replace my brakes.Funny think is I contacted Chevy and never received a answer. Scot
