Old 06-25-2006, 09:57 AM   #1
62 short step
62 short step's Avatar
front axle
I'm thinking about changing my closed knucle axle to an open knuckle. Would the ones off of 73-87 chevys be a direct bolt in? That way my disc brake change would go in at the same time. Jeremy
62 short step is offline   Reply With Quote
Old 06-25-2006, 11:25 AM   #2
shelby987
shelby987's Avatar
Re: front axle
Doing this same swap right now on my 70 k20. I am not sure what axle you have under a 62, is that a dana or a napco front axle?
The swap will require new front brake flex lines, new spring plates and u-bolts (if your current axle tube is 2-3/4" and not 3" in diameter.
To accomodate the disc. brakes you will also need a new MC, new proportioning valve, and a host of misc. fittings (or all new hard lines) to connect to the proportioning valve.
Be prepared, I would say my swap has cost me between $250 and $300 in all the misc. parts and pieces (and thats doing it on the cheap).
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 06-25-2006, 12:38 PM   #3
62 short step
Re: front axle
Its a dana 44 5f what I have on it now. It is the stock axle as far as I know. Thanks for the info! Jeremy
