06-25-2006, 11:03 AM | #1 |
chevy truck fan
ebrake cable layout
well i am now trying to hook up the ebrake on my 72 chevy 2wd swb p/u. would you guys be able to tell me how the cable(s) run along the frame & where the cable support rods go on the frame???? iam also having difficulty with reconnecting the cable from the cab to the rest of the cable run(where the nut & curved bracket attach on driver's side) if there might be someones pics available from when they did it that would be a big help as well!!!
thanks!!! rodstored-72 |
06-25-2006, 02:14 PM | #2 |
Post Whore
Re: ebrake cable layout
I have a 72 parts truck sitting outside with the cab removed I will see if I can grab you a couple of good pics in a few minutes.
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons |
06-27-2006, 10:41 AM | #3 |
chevy truck fan
well,
let me try this again. i am wondering how to hook up e-brake cables on my '72 swb 2wd p/u. i have the cpp rear disc brake conv. kit & i bought the e-brake cable kit from them as well. has anyone done this same or similar setup & how did you get the cables ran & hooked up??? i seem to be about 4" short of being able to hook everything up. please please help!!!! thanks!!! rodstored-72 |
06-27-2006, 05:12 PM | #4 |
member #16
This may or may not help. This is from LMC online catalog p 143. It will show better if you view through the catalog.
http://www.lmctruck.com/
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
06-27-2006, 05:26 PM | #5 |
Nothings as cool as my 72
Not to highjack, nut I need this info as well. I've looked at the diagram in the LMC catalog, but its not that great.
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. |
06-28-2006, 10:30 AM | #6 |
chevy truck fan
hey guys,
thanks for the info. yea i have the catalog(S) & i basically have it routed ,but i seem to be about 4" short of being able to connect it all. i have replaced the rear with a rear disc brake kit from cpp & i purchased the e-brake cable kit to prevent this, but it seems to not have helped so i was trying to find someone who has done a similar setup to see what they had to do... thanks again! anymore help???? rodstored-72 |
06-28-2006, 10:41 AM | #7 |
I have the same rear brakes on my 72 short bed and I had to shorten the cable for it to work. I live in Scottsdale if you need to see how I installed the e brake PM me and we could make arrangements for you to look at mine.
06-28-2006, 11:09 AM | #8 |
TOTY 2006
Here is a shot from the 1967 truck service manual....
06-28-2006, 03:52 PM | #9 |
chevy truck fan
john,
thanks for the shot. i tried looking in the assy. manual but didn't find anything yet. i will continue... trying to find something in there without it being marked is near impossible! |
06-28-2006, 03:53 PM | #10 |
chevy truck fan
fastfun,
i pm'd you... thanks!!! rodstored-72 |
