06-25-2006, 10:15 PM | #1 |
Its Magically Delicious
strange noise while turning
seems to be coming from the front ..... kinda a "low growly farty rub" noise
dont notice it while cruising in a straight line ... im thinking it might be tierods or balljoints .. does this sound about right ... whats the best way to check both these areas?? thanks
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
06-25-2006, 10:24 PM | #2 |
Junior Member
Re: strange noise while turning
You might check your wheel bearings.
Clif '68 C/10 LWB, 327, TH400, 12 bolt |
06-25-2006, 10:55 PM | #3 | |||
Union Electrician
is it a consistant pace? possible loose lugnuts/wheel???
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
06-25-2006, 11:25 PM | #4 |
it comes and goes while the turn is being made
06-26-2006, 11:05 AM | #5 |
Take it in to Les Schawbs or Midas, ask them to check & advise. Ask them to show you exactly what they see wrong and explain in detail why it makes that noise. When they give you a quote for the fix just tell them your broke until payday. Then go buy the parts yourself and fix it. A free professional diagnosis.
06-26-2006, 04:06 PM | #6 |
Just hang'n around
Could be a worn power steering pump.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year. |
06-26-2006, 10:25 PM | #7 |
I've had the lug nut problem before. Its sorta like a mix between a grind and a squeak,jack it up just clear and have somebody hold the brake while you try to roll it front and back, it won't move much mostly you'll just feel it. While its up if you wanna check the ball joints get your buddy to slip something under the tire and lift up and down on the tire while you watch the joints. If they're worn bad you can see it easy enough. If I had to guess though I would first check the power steering pump if it only does it while turning. Then check for a bad wheel bearings.
Kevin 1967 C-10 swb fleetside 1968 C-10 stepside 1999 Z71- sons dd 1999 2wd silverado-my dd 2003 Tahoe- wifes dd |
06-26-2006, 10:26 PM | #8 |
as you turn the wheel? if so, add power steering fluid.
06-27-2006, 01:06 AM | #9 |
Just hang'n around
Never could hear bad wheel bearings. The best way to check them is to fell your hubs after a short drive. If they are hot, they are bad. If had them go out on a few different vehicles and never heard it coming.
07-21-2006, 07:54 PM | #10 |
finally got around to doing something about it .. ran to schwab and both guys there said it sounded like it was definetly coming from the rear end of the truck ...... hope its not my 2 year old eaton posi
08-19-2006, 05:10 PM | #11 |
Just hang'n around
So, was that the problem? Mine (similar sound to yours) seems to be getting worse. I'm thinking it to be ps pump going out.
08-20-2006, 03:30 AM | #12 |
I survived Dead Man's Curve.
One way to check is just turning while at stand still. This is when the pump is working at it;s hardest, becasue the truck (not moving) does not assist in turning. Understand? It's harder to turn the wheel at standstill. Anyway, if it makes noise then (try turning slowly and listen for noises). I know mine makes the rub noise and that's just the PWR steering pump. Mine is a junkyard part, no naturally it is worn down.
In this case, really the only thing you can do is get another pump or check the fluid level.
"The people should not be afraid of their government. The government should be afraid of it's people." "The Hurricane" 1967 Chevrolet C10 350 Eight Cylinder, 700R4 BowtieOverdrive Cherry Bomb... Disturbing the Peace Since 1968. Last edited by ThatOneBlue67; 08-20-2006 at 03:31 AM. Reason: Forgot something... |
08-20-2006, 06:54 AM | #13 |
first thing i would check is the ubolts holding the lower control i had the same problem and could not find it untill i ws pulling in to my dads house to use his tools and the lower control arm rear ubolt came out i was a l bolt after that. i checked the rest and thay were all loose i removed and cleand them thay were loose enuff to move around and it would groan as thay would move it is kind a an ohhhh crap moment when your front end drops down on one side hehehe other then that i dont know most of the time thay pop when loose but mine groaned so try there
08-20-2006, 04:22 PM | #14 |
Just hang'n around
Last night I coasted with the truck in neutral...no sound. But, as soon as I applied power again, there it was. So at idle, no noise...powered up....big noise. To me it sounds like sheetmetal vibration...but a loose bolt somewhere may sound the same.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year. Last edited by Steelawork'n; 08-20-2006 at 04:22 PM. |
