06-26-2006, 09:14 AM | #1 |
powertrax
has anybody tried a powertrax system in there truck? how do you like them? are they hard to install? any draw backs? are they worth the money? thanks for any information
06-26-2006, 10:16 AM | #2 |
Re: powertrax
I saw an installation on one of the TV truck/car shows some time ago. It looked fairly easy for a novice like me. I plan to use one when I get to my rear end, but do not know how they perform in the real world.
06-26-2006, 10:31 AM | #3 |
Re: powertrax
I just installed the Powertrax (Richmond) Lock Right locker in my open 12 bolt. It took me about 2 hours total, I cleaned and inspected everything inside the rear end while I had it opened up so it took a bit longer than it had to. The actual installation was really easy if you know what each of the parts inside a rear end is (no pictures with the instructions).
Some people complain of it clicking, but mine is fairly quiet to me just because I have Flowmasters dumped after the axle and can't hear it. I am using the recommended 85W-140.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
11-10-2006, 10:36 AM | #4 |
Re: powertrax
ttt
11-10-2006, 11:13 AM | #5 |
Re: powertrax
Strong and dependable and easy to put in to boot.
11-10-2006, 12:32 PM | #6 |
NCStroker
Re: powertrax
i have read alot of stuff about them blowing up or just not working. i was also thinking about doing the powertrax, but am now searching the junkyards for an eaton.
1971 Chevy C/10-Built 383 Stroker |
11-10-2006, 01:29 PM | #7 |
Re: powertrax
can you provide the sorce? i wanna get a powertrax unit, and would be instrested in the reviews
11-10-2006, 03:15 PM | #8 |
Re: powertrax
We covered this the other day: http://67-72chevytrucks.com/vboard/s...d.php?t=215726
I wouldn't drive a big-block with one. A mild-to-medium small block shouldn't have any issues, unless you are lifting it and going with much larger tires. If it is a street rig you really want a limited slip for better road manners. Check out the Eaton or a Detroit TrueTrac. Yes, they are easy to install, as long as there are no hiccups. When I put the Lock-Right in mine, I found that at some point before my ownership my axle had ingested some water. The outer end of one side gear had rusted and pitted, even though everything else was cherry. Took me nearly an hour of cussin' and beating with a hammer and a brass drift to dislodge the side gear from the carrier.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... Last edited by 69TowRig; 11-10-2006 at 03:17 PM. |
11-11-2006, 05:13 PM | #9 |
402 BIG BLOCK
Re: powertrax
my brother put one in his 03 gmc, blew after 3 days, powertrax wouldn't warranty. good luck.
1967 C10 swb 1970 GMC Jimmy 4x4 2005 Chevy tahoe Z71 2001 Chevy impala |
11-11-2006, 07:05 PM | #10 |
Re: powertrax
11-11-2006, 07:33 PM | #11 |
402 BIG BLOCK
Re: powertrax
beacuse they said it wasn't there fault, we even sent it to them directly took 6 months to find out that they weren't going to warranty it.
11-11-2006, 07:39 PM | #12 |
Re: powertrax
oh sure they'rew just as good as a posi// makes you wonder about the dumbass corporate types at gm and ford , why do they spend so much more on real posis when the could save somuch on the makebelive stuff??? and have bigger profits???
