06-26-2006, 11:24 AM | #1 |
fuel tank plumbing questions
i replaced the tank in my 71 with a 40 tank from a 87 sub. i removed the electric pump and extended the pickup tube. the sub tand has a vent with a ckeck valve that alows fuems to escape but no air tho enter the tank that went to the evaperative canister whitch my truck didn't have , what should i do with this? add canister? plug it and use vented cap? next ? tank is also plumbed for a return line my holly fuel pump is not should i plumb this to front of truck in case i want it later or plug it at tank? next ? where these tanks get their make up air? dotheir caps alow air to enter and fuems to not escape to keep them from collapsing or vapor locking?
common sense isn't so common anymore |
06-27-2006, 09:29 AM | #2 |
Re: fuel tank plumbing questions
no thoughts on this?
06-27-2006, 11:42 PM | #3 |
62 veiws and not even a guess
06-28-2006, 06:27 AM | #4 |
Man I hate to see threads like this. Let me take an uneducated stab at this.
Since the tank going in a 70 then I say set it up like a 70 tank, no return line and a vented cap. My 2 cents |
06-28-2006, 10:02 AM | #5 |
thanks tugowar thats what i did yesterday just ran the 3/8 line to front and stubbed other two out where they were accesable and caped return
06-29-2006, 01:53 AM | #6 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-29-2006, 10:27 AM | #7 |
my truck is a shortened 3/4 4wd. the rear frame crosmember was damaged so it was removed and i rebuilt around the tank.i had to add two "back on the rear of the frame but only two" high to clear the rear bed cross member and keep tank far enough rearward to clear the diff under suspension load
common sense isn't so common anymore Last edited by wibilly; 06-29-2006 at 10:45 AM. |
