Old 06-26-2006, 03:36 PM   #1
Tim4altd
1983 C10 weights
Hi All
an someone please tell me the curb weight for a shortbed C10
Also the gross laden weight
Lastly, where is the reverse switch located, Column or trans??
Any info most appreciated
Tim4altd is offline   Reply With Quote
Old 06-26-2006, 09:46 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: 1983 C10 weights
The shortbed C-10 is around 4000 lbs without a load. I don't think I can safely answer the gross laden weight. The truck and axles on most are rated as 1/2 ton, but I have seen much more in one truck's bed. I can also remember the day that a person could order a shortbed 3/4 ton truck--now those were the days.
The reverse switch is on the column (on top, by the firewall, inside the cab)
piecesparts is offline   Reply With Quote
Old 06-27-2006, 12:35 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Hey another 83 on the ROAD!!! Welcome to the site.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 06-27-2006, 04:04 PM   #4
Tim4altd
Thanks for the help
4000lbs tare weight seems a little heavy for a short bed c10 though???
Anyone else got any info???
Old 06-27-2006, 04:18 PM   #5
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
piecesparts is close.
The curb weight for a Fleetside is at 3,470 lbs. Add 450 lbs. (+/- 150lbs.) for the model weight.
The weight scale at the local gravel pit weights in my truck between 4,500 - 4,600 lbs with the dual tanks nearly full and me sitting behind the wheel. But, I don't know how accurate their scale is.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 06-27-2006, 04:50 PM   #6
Russell
Professional Grade
Russell's Avatar
My 77 Short Stepper weighed in at 4200 at the local garbage scales It has a 350 / 700r4 combo, without many other options.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-27-2006, 08:53 PM   #7
piecesparts
My 84 GMC short wide bed weighed in at 4001 lbs before the fiberglass topper was installed. I have since removed the steel hood and installed a fiberglass cowl hood, which changed the weight about 60 lbs, to the lighter side. I have a 383 stroker/700R4 combo with a 12 bolt rear end.
Old 06-28-2006, 10:46 PM   #8
love it loud
Calibration Engineer
love it loud's Avatar
'81 swb stepside 350/350 weighed in at 3720 lbs, bone stock
CANADIAN CONNECTION
love it loud is offline   Reply With Quote
Old 06-29-2006, 01:10 PM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Generally SWB's fall between 3800 to 4200 depending on the equipment installed. Base models with no power, no carpet and no A/C and base radio will be the lightest, generally around 3800lbs
Start putting power windows, power locks, larger mirrors, carpet, A/C system, speakers, more trim, all the wiring associated with this, power brakes, power steering, heavy duty suspension, HD brakes, bigger radiator, bigger motor and it starts getting heavier...
4000lbs is right in line with one of these trucks... the only way to know for yours exactly is to run it on some scales. I have weighed quite a few.. My newest one is going to be a lightweight!
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
