06-27-2006, 01:25 AM | #1 |
Just hang'n around
What size Pipes???
I have a 283 bored 30 over with an alluminum intake under a 600 cfm Holley. It has headers funneling into stock-like 1.5" pipes and standard mufflers.
What sized exhaust pipe should I be running?
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year. |
06-27-2006, 02:03 AM | #2 |
Gone Fishing
Re: What size Pipes???
i would run 2 1/4
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
06-27-2006, 05:02 AM | #3 |
its all about the +6 inches
2 inch would be more than enough onless you plan on spinning 7000 RPM.
06-27-2006, 07:43 AM | #4 |
I'd go with 2" as well....the smaller pipes will give you more low end power. Bigger pipes will rob it from you. Here's what I go by...
200-300 hp = 2" 300-400 hp = 2.25" 400-500 hp = 2.5" over 500 = 3"
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
06-27-2006, 04:39 PM | #5 |
Dork For Days
I'd go 2.25". I don't agree with the myth that bigger pipes hurt torque. I've seen many tests that show no loss whatsoever. 2.25" probably costs the same and certainly flows better.
If you were turning 7000 RPM you'd want at least 2.25", but more than likely 2.5". I assume, of course, that this is crimp-bent pipe. If you're planning on mandrel bends, 2" would be plenty for a mild motor of that size.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status! 1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60' 2007 Dodge Charger SRT-8 2008 Cadillac CTS All-American garage, baby! |
06-27-2006, 05:54 PM | #6 |
Mandrel bent is the only way I'd consider it done on my truck. If you go this route, 2" is plenty good for your motor. Never seen a warmed over 283 hit anything over 5500 rpm and live.
I wouldn't even consider crimp bent pipes.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. Last edited by Gray Ghost; 06-27-2006 at 06:27 PM. |
06-27-2006, 09:30 PM | #7 |
If you plan to have traditional crmp bends , than Id go 2.25 . If your gonna have nice manderal bent exhaust, than 2" would be fine.
75 GMC C-15 short/step factory 454, lowered |
06-27-2006, 10:48 PM | #8 |
Aluminum slot wheels rule...
2 1/4in. If it's in your 68, I'd buy the whole 2 1/4in. exhaust kit from LMC for 150 bucks with mufflers and all.
06-28-2006, 10:29 PM | #9 |
Just hang'n around
How does the LMC kit fit? Is there any welding?
06-29-2006, 10:06 AM | #10 |
I've read it fits good, and it clamps together. You could have it welded if you want. My truck doesn't really have an exhaust, just rusty pipes cut-off under the cab.
06-29-2006, 11:20 AM | #11 | |
Next project: 1970 K10
Also, the kit is made up with mandrel bent 2.25" aluminized pipe. For the money, I think it is a great buy! You can get it exiting straight out the back (outside the frame rails from the axle back), or exiting just behind the tires.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 06-29-2006 at 11:21 AM. |
06-29-2006, 11:50 AM | #12 |
Dork For Days
The LMC kit is mandrel bent?
How much is the mandrel bent kit? Is it available without the mufflers? Dang, this sounds like the way to go for me, too. I was considering a quickie crimp-bent 2.5" system for my 402. 2.25" would be plenty with mandrel bends and it sounds like it might be cheap too!
06-29-2006, 12:01 PM | #13 |
Yup! Exit behind the rear tires is $199.95, and exit straight out the back is $229.95. That is with turbos. Glass packs or $10-$20 less. And the prices are the same for 2wd or 4wd.
[edit]Hmmm, now that I look closer at the catalog, they are only available for small blocks, which is
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 06-29-2006 at 12:04 PM. |
06-29-2006, 12:38 PM | #14 |
Dork For Days
That's weird. What's the difference between SB and BB on the pipes? I assume these kits are made to bolt up to the manifolds.
Do they offer a kit for use with headers? What about without the mufflers? (already got some decent ones)
06-29-2006, 12:50 PM | #15 |
The difference is probably the size, angle, and exact location that the pipe exits the manifolds. The BB will definately be wider.
There is no "mufler delete" option that I can see, and since they are made to bolt up to the manifolds, I suppose you could make a cut and weld on collectors.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
06-29-2006, 09:33 PM | #16 |
That was my only concern, too, about the headpipes bolting up to the V6 manifolds.
