Old 06-27-2006, 01:25 AM   #1
53burb
53burb's Avatar
Vortec Heads & Block
I looked at some heads with casting#14102193. According to Mortec.com, these have 1.94" & 1.5" valves. And it shows that these were from '87-up. They were center bolt heads & the block had the provisions for the fuel pump, not sure about the camshaft. So is this a Vortec engine & heads???
53burb is offline   Reply With Quote
Old 06-27-2006, 02:02 AM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Vortec Heads & Block
They went to the vortec in 96. It is they same style bolt pattern for the valve covers but a little bit differnt casting.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 06-27-2006, 02:05 AM   #3
boot85
71 Chevy
It may be a vortec engine but I doubt it. The vortec flavor had more of a multiport injection design. Not the old crappy throttle body injection. I might be wrong, this is only my opinion.
71 C10
72 C20
62 Chevy II 2DR HT
boot85 is offline   Reply With Quote
Old 06-27-2006, 03:10 AM   #4
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
vortec sbc blocks had plastic timing chain covers, and are roller cam motors.
vortec sbc heads have 4 bolts per head for the intake...... tbi engines, have 6 intake bolts per head for the intake with the center two "canted" they are not at the same angle as the other ones. just from what you are describing, it sounds like a tbi engine
tommie is offline   Reply With Quote
Old 06-27-2006, 09:27 AM   #5
53burb
53burb's Avatar
The two center bolts were straight & not angled. I did not look at the timing cover. There is no intake on it. I'm thinking it was a TBI engine like everybody else is thinking. Maybe, I will give him a call tonight & have him verify the bolt holes per head....
Thanks everybody,
Chris
Old 06-27-2006, 11:59 AM   #6
70rs/ss
70rs/ss's Avatar
Some refer to what you have as early Vortec, I have one and they are a one piece rear main with non-roller cams. These are not the performers like the 96 and up Vortecs. Check out Carcraft.com they have a cylinder hear flow chart, you just look for your head and they give you the flowbench numbers as well as an opinion based on all the other heads tested.
70rs/ss is offline   Reply With Quote
Old 06-27-2006, 12:41 PM   #7
Boog
laying low
Boog's Avatar
This is a late 80's early 90's tbi engine. Not Vortec. My two 88's have that very engine.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-27-2006, 12:55 PM   #8
70rs/ss
70rs/ss's Avatar
Yeah, TBI, but some call it early Vortec. I have one from a Van. The heads are good, and the block is as good as any core, so build it, the heads can always stand work, but if I was you, I'd hold out for a "real" set of Vortecs. New they are $500, and if you buy used and have em done, it'll be close to $5 hundred, buy new!!
Old 06-28-2006, 02:01 AM   #9
jimfulco
-193 is the "swirl-port" head, isn't it?
jimfulco is offline   Reply With Quote
Old 06-29-2006, 05:48 AM   #10
53burb
53burb's Avatar
Thanks for the help everybody. I passed on them. I was pretty sure the Vortec heads started in '96 when GM finally went to MPFI on their trucks. Just wanted to make sure.
Old 07-05-2006, 04:51 PM   #11
stroked71
Here is the casting number for the real vortec 350 heads 10239906 96-up. 1.94 and 1.50 valves 64 cc chambers 170 intake ports exc. exc. 8 intake bolt's not 12.
stroked71 is offline   Reply With Quote
Old 07-05-2006, 07:51 PM   #12
cableguy0
the vortec is the chamber design. theres no such thing as an early vortec. the early heads were simply a centerbolt head for tbi injected trucks. definately nothing spectacular
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-05-2006, 11:38 PM   #13
Tom
driving is in my blood
Tom's Avatar
You forgot the 062 castings, also L31 vortec's
Old 07-06-2006, 09:15 AM   #14
stroked71
Ya I know I thought about that after I posted lol.
Old 07-06-2006, 10:43 AM   #15
68haywagon
I'm watching you!
I have a question....not to stir sh*t, but how come my 93 4.3l says Vortec on the window sticker. Is that when they started using the name or does it actually have something to do with the heads? It is a TBI motor.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 07-06-2006, 01:35 PM   #16
cableguy0
the 4.3 vortec started earlier than the 5.7 vortec.
Old 07-06-2006, 01:40 PM   #17
68haywagon
I'm watching you!
Ahh ok. Thanks.
Mike
