Old 04-21-2002, 07:12 PM   #1
shortbed70
shortbed70's Avatar
Post camshaft Q'ssss
I'm going to rebuild my stock 350 and am wondering what cam to use. I have a comp cams 280H but I don't want the thing to rattle my teeth loose when idling at a stop light but I do want a liitle lope. I'm going to use heads off my old street stock motor because they can handle a nice lift. Any suggestions would be helpful. Oh yea I've got th350 tranny w/2200 stall.
1970 shortbed(project)
350/350 dropped 4/6 21/2" flowmasters.Plans for BIGBLOCK.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-21-2002, 07:27 PM   #2
sam's 72
Post
Going to need to give us a little more info, what compression ratio are you going to run? What are the numbers on the heads, what intake are you wanting to run, do you want hydrolic cam, hyd roller, solid lift?
sam
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
Old 04-21-2002, 07:59 PM   #3
Mike C
Mike C's Avatar
Post
For a mostly stock rebuild, maybe mildly worked heads, an intake and headers, I'd run the Crane Energiaer 266. Excellent torque and power with a nice idle. Can't beat the $80 price tag with lifters, either.
70 GMC 3/4 ton Sierra Grande 402/TH400
72 Jimmy 4WD 4spd 4" & 35's
64 Corvette Coupe
68 Camaro 'vert TPI & TH700
69 Z/28 355 12.6's @110
72 Datsun 240Z-ol' reliable
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
02 GMC 2500HD 4x4 Duramax
Old 04-21-2002, 08:30 PM   #4
shortbed70
shortbed70's Avatar
Post
I'm running about 9:1 with the heads 76cc chambers mildly ported with 1.94-1.50 valves. I want a hydraulic cam for the low maintenece and cant afford a roller. I don't know the # on the heads right off hand but they worked well on my 355 with .504 lift. I'm going to run a performer rpm intake but the cam they offer is a little to big I think. For carb I want to run and edel. 1406 but I now have a holley 650 vacume secondaries. That motor is DONE lets just say KABOOM.
350/350 dropped 4/6 21/2" flowmasters.Plans for bigblock or just a little stroker.
Troy
Big Red Dog build
