70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Extra Wire Question !!
I noticed this wire wasn't attached to anything and my truck runs fine. It comes from the main harness and seems to me that it is for the alternator as it extends perfectly to there and has ( I think) an alternator connection on it. I also am putting a pic of my alternator and distributor on here cause I think the alternator has been upgraded cause of the electronic ignition.. Can I clip this wire without causing a problem? .. I plan to put a Ron Francis Wiring Kit in the truck this coming winter .
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: Extra Wire Question !!
i think thats for the tsc, transmission controlled spark. it's an emissions thing most people rip out. it should go through the firewall and there's a relay on the inside near the fuse panel. look for the other end of that pink wire around there. if it's not connected to some solenoid on the carb, might as well rip it out.
Holy Moly that is Pepto Pink
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
#4 | |
Semi-Senior Member
The wire may have gone to an idle solenoid on the carb, especially if the truck origionaly came with a 6 cly. Do you know if it did?
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
#5 | |
The truck originally came with a 350 4bbl engine and automatic trans. and I bought it with the the 396 /350hp with the TH400 that is in it now.
#6 | |
Maybe a silly question, but is that stock, I know they painted some doozies in Canada?
#8 | |
member #16
![]() Join Date: Dec 1999
It is hard to tell what the wire was originally for. You truck has later engine with alt on pass side. The only way I can think of is to trace to other end of the loom and go from there. If every thing works without it you can clip it or tie it back.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
It looks like someone has added the pink wire as there were no pink wires in that part of the stock harness. (The TCS system had its own separate harness as an add on). The harness has been retaped with electrical tape so someone has been busy in the past. I wonder if it was not used at one time for an aftermarket ammeter.
Jim |
