Old 06-27-2006, 06:42 PM   #1
5150
C10 Club Tennessee
5150's Avatar
How to swap old Alternator to this new one
This is another chapter on the serpentine swap. My old alternator doesn't fit in the bracket. Not that big of a deal because a mechanic buddy of mine gave me this one last week. I was just taking it for the pulley, I thought. Now I have to hook it up. Any advice would be appreciated. I've read the FAQ about the alt's but that didn't seem to apply to me.
Appreciate it.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 06-27-2006, 08:39 PM   #2
neonlarry
neonlarry's Avatar
Re: How to swap old Alternator to this new one
This may help,because it looks like you need plug and wiring anyway:
http://www.madelectrical.com/catalog/cs-130.shtml
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-27-2006, 11:29 PM   #3
5150
C10 Club Tennessee
5150's Avatar
I can get another plug that plugged into that alt originally when I go to the junkyard tomorrow. Is there a diagram that will help me wire it up?
Bryan
www.gmtruckshow.com
Old 06-28-2006, 06:28 AM   #4
TugOwar
ttt
TugOwar is offline   Reply With Quote
Old 06-28-2006, 07:11 AM   #5
neonlarry
neonlarry's Avatar
If you do a search its been covered many times.
Old 06-28-2006, 09:00 AM   #6
5150
C10 Club Tennessee
5150's Avatar
hey Larry, I found a post about it when Mocwon did it, but still a little confused about the resistor part and what to wire up on the voltage regulator. Leaving now to go to the junkyard. I'll try to grab that plug in when I get there.
Bryan
www.gmtruckshow.com
Old 06-28-2006, 01:18 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Look at this it may help.
http://www.chevelles.com/techref/tecref14.html
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-28-2006, 04:28 PM   #8
neonlarry
neonlarry's Avatar
The VR does not get wired in just dump it. The resistor needs to be wired to an ignition ON source.
Old 06-28-2006, 06:10 PM   #9
krue
Designated A-hole!
krue's Avatar
I bought a pigtail with the correct resistor wired in to it and spliced it to my harness. It was pricey at $20 but I've had no troubles with it.
The thing that confused me is the conversion write up for the most part converts you to the internally regulated alternator that was used prior to the serp. style alt you need. Then you need the pigtail I bought to use the newer alt. I just eliminated the middle man and soldered the pigtail to my harness and it worked. PM later and I'll give you my number if you wanna holler at me.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-28-2006, 09:23 PM   #10
krue
Designated A-hole!
krue's Avatar
Here's my plug. The larger contact on the left is the red wire from the battery (same as original basically just goes to the post on the back of the alt, then I ran the red wire on my plug to the post). The yellow wire is the 3rd from the left w/resistor soldered in and it's connected to the brown wire in the original harness.
www.daveramsey.com
Old 06-28-2006, 09:35 PM   #11
5150
C10 Club Tennessee
5150's Avatar
Okay, here's the wire i got from the junkyard today.
Bryan
www.gmtruckshow.com
Old 06-28-2006, 10:02 PM   #12
neonlarry
neonlarry's Avatar
lets see the other side where the wires attach to the contacts. That one wire looks like it goes tothe 'L' pin there is a contact in the plug for the 'S' pin you might have to solder one on there.
Old 06-28-2006, 10:07 PM   #13
5150
C10 Club Tennessee
5150's Avatar
here it is
Bryan
www.gmtruckshow.com
Old 06-28-2006, 10:16 PM   #14
neonlarry
neonlarry's Avatar
Sh**. Well looks like you might have to dig the epoxy\plastic (whatever it is)out so you can get at that other contact and solder a lead on there. I've never seen one with just one lead. the 'L' terminal is to excite the Alt and the 'S' terminal is for voltage sensing.
Old 06-28-2006, 10:18 PM   #15
5150
C10 Club Tennessee
5150's Avatar
I might just buy this damn thing here:
http://www.partsamerica.com/ProductD...artnumber=8078
I know Chickenwing used it and it worked for him.
Bryan
www.gmtruckshow.com
Old 06-28-2006, 10:23 PM   #16
GMan69
GMan69's Avatar
Bryan, you have the same alternator as Putter and Palf70step. Putter called the guy at madelectrical (I think his name is Mark, but don't hold me to it) and said he was very helpful.
George Morgan
Hernando, MS
'69 C-10 swb fleetside
'72 GMC swb Stepside
GMan69 is offline   Reply With Quote
Old 06-28-2006, 10:23 PM   #17
neonlarry
neonlarry's Avatar
If I remember right he said it included the resistor too. Sounds like the easiest way to go.
Old 07-05-2006, 06:35 PM   #18
5150
C10 Club Tennessee
5150's Avatar
Well, I bought that plug that chickenwing recommended to buy from Advance. But I didn't look real close at my alternator. Igotachevyor2(brandon) came over and helped wire it up and today when i was done bolting all of the serpentine stuff up I couldn't get the plug to go in. My plug is oblong and that plug was rectangular. I'm going to go to the junkyard tomorrow and find an oblong one off of a car somewhere. I had to cut the new wire harness off, so when I get the harness from the junkyard I'll post a pic of it also so I can get a little help of what to connect where.
Bryan
www.gmtruckshow.com
Old 07-06-2006, 02:06 PM   #19
5150
C10 Club Tennessee
5150's Avatar
Okay, just got back from the junkyard and I believe I got the right plug(this time). I plugged it into the alternator and it fit perfect. Here's a pic of the plug I got. Can you guys tell me what needs to connect to what on the post above this one of my alt wires on the truck. Also which one of these do I need to hook the resistor up to.
Bryan
www.gmtruckshow.com
Old 07-06-2006, 05:18 PM   #20
neonlarry
neonlarry's Avatar
http://67-72chevytrucks.com/vboard/s...light=resistor
Old 07-06-2006, 06:43 PM   #21
5150
C10 Club Tennessee
5150's Avatar
Hey Larry,
By that diagram on that post:
Pink/Gray(2 wires on harness) go to MY orange wire on the post above
Black wire goes to MY green wire on the post above(through a 75 ohm 3 watt resistor)
DO I FINALLY GOT IT!!!!!!!!!!!!!!!!
Bryan
www.gmtruckshow.com
Old 07-06-2006, 10:10 PM   #22
5150
C10 Club Tennessee
5150's Avatar
ttt
Bryan
www.gmtruckshow.com
Old 07-06-2006, 11:27 PM   #23
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Did you go to the website I posted above?
VetteVet
Old 07-06-2006, 11:40 PM   #24
5150
C10 Club Tennessee
5150's Avatar
yes, but I'm lost.
I bought the plug from Advance that I posted the link for above. Thought I had it but got the wrong plug. So I've wired the VR like the the chevelle website says.
Bryan
www.gmtruckshow.com
Old 07-07-2006, 12:17 AM   #25
VetteVet
Msgt USAF Ret
VetteVet's Avatar
like Larry said you ditch the voltage regulator and just wire the wires together and get rid of the white one. If you have the idiot light you need the brown wire hooked into the alt for the resistance. If you have an ammeter then you need to hook and additional resistor into the plug wiring. I'm confused about the statement Larry made about the diode in the alternator blowing without the resistor. I take it to mean if there is no resistance then it will blow the diode or does it mean that you need the resistor as well as wiring the brown wire to the alternator. May be he will clear this up for us. In the last paragraphs of the chevelle website he tells about the resistor and he explains how to wire the cs alternator into the harness. Here is a copy/paste of what he says.
(On the connector that I got, there were four wires and the body of the connector had identification letters. Here are the id letters and the color wires (don't count on the colors to be the same as what you get).
"S", this was a heavy gauge, red wire.
"F", this was a small gauge, brown wire.
"L", this was a small gauge, brown/red wire.
"P", this was a small gauge, brown/white wire.
The red wire from "S" gets connected back to the output terminal of the alternator just like in the "SI" swap.
The brown/red wire from "L" gets connected to what is shown in the diagram above as the blue wire. It's this wire that comes (indirectly) from the idiot light and it energizes the alternator.
The wires from "F" and "P" are not used!
As an additional note; AC Delco sells a "conversion" wiring loom if you are changing from a "SI" to a "CS" and it is nothing but a few short wires and two connectors. One connector plugs into the existing wiring loom connector that was plugged into the "SI". The other new connector plugs into the "CS". What's real important to note is that there are two different types. One is "non-resistor" and the other has a resistance in it. You want the "non-resistor" one if you are going to keep the idiot light. Use the "resistor" one if you are getting rid of the idiot light. Be sure to read the "notes" section of this page before jumping!!)
I mainly posted this website for you to see the mounting brackets and other hardware but I hope the wiring info helps. VV
VetteVet
