Old 06-27-2006, 11:09 PM   #1
perrosinpata@aol.com
perrosinpata@aol.com's Avatar
Valve Ground Quest
I have the ground for the solenoids grounded to the frame and they wouldnt open when I hooked up the power to the switch box.I also had a problem with the air compressor starting.I bought my kit from suicidedoors.The 8 valeve kit.
perrosinpata@aol.com is offline   Reply With Quote
Old 06-28-2006, 12:22 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Valve Ground Quest
Do you have a good ground at the chassis? Do you have a ground strap from the motor to the chassis or one from the battery to the chassis? Try running some jumper wires from the battery to the 12V input and the ground input at the valves to test them. Do you have 12V at the battery?
PBFAB.COM is offline   Reply With Quote
Old 06-28-2006, 12:25 AM   #3
Thanks for the advice
Old 06-28-2006, 01:07 AM   #4
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Use one of these to hookup your valves and ground. Much cleaner.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 06-28-2006, 09:07 AM   #5
Shane
Shane's Avatar
'cept, don't mount it on a peice of wood
Shane is offline   Reply With Quote
Old 06-28-2006, 02:39 PM   #6
camaro__thunder
Not mine lol Found this pic online !
My Project 69 SWB
Old 06-30-2006, 11:08 PM   #7
I have 12v on the battery
I tried my valves with the jumper straight to the battery no good
I have a good ground
My relay has one wire that isnt in my diagram?
Old 06-30-2006, 11:21 PM   #8
PBFAB.COM
PBFAB.COM's Avatar
Is it the middle terminal in the relay? Often times the middle wire on a 5-wire relay goes unused.
Old 07-01-2006, 11:39 PM   #9
Do you think I need to have all three prongs on my valves hooked up?
Old 07-02-2006, 01:14 AM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
Here is a relay diagram.
dwcsr is offline   Reply With Quote
Old 07-02-2006, 02:27 AM   #11
71swb4x4
71swb4x4's Avatar
No, just two.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
