Old 06-28-2006, 09:19 AM   #1
BowTieOgre
Front End Rebuild
I will be converting the front Drum setup on my '70 to a disc setup using '71 spindles and want to know if I can reuse my controls arms? If I understand correctly the balljoints and tie rod ends are different on the '71 but everything else remains the same...is that the case?
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 06-29-2006, 09:05 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Front End Rebuild
You can reuse the control arms, just change the ball joints and tie rod ends to 71/72. You will also have to replace the center draglink with one from a 71/72. Did your 70 come with power brakes? I would change the master cylnder and proportioning valve also.
Hart_Rod is offline   Reply With Quote
Old 06-29-2006, 10:06 AM   #3
BowTieOgre
It did come with a power brakes but im going to replace the booster, mc and prop valve with a new one. Thanks for the info Rob.
