Old 06-28-2006, 11:54 AM   #1
shelby987
shelby987's Avatar
what's it worth 67 GMC w/351
Came across a 67 GMC the other day, and I was wondering what it might be worth.
Body in OK shape, some surface rust, and 'iffy' rockers and cab corners.
351 V6, Power steering, power brakes, small rear window, factory gauges including tach, 3/4t 2wd with what looked like a dana 60 rear, oh yeah, and a 4 speed w/creeper (sm 420/465 not sure).....was just wondering what this might be worth, its a pretty odd combination of options (who sprung for the PS and not the automatic?).
One draw back.....it had a sunroof......and while it has some more rare options, pretty sure that WASN'T one of them.
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 06-28-2006, 01:06 PM   #2
Americanrider
Re: what's it worth 67 GMC w/351
SM 420= Reverse is over to driver & down, last used in 67 unless a PO installed it in a newer truck. SM 465= Reverse is over to Pass side & down. I have read some postings by members that the 351 motors & heads a keepers for those who like the big V-6s. If you can check behind the seat back, you might find a build sheet there. GMC mostly (all most always) came with the Dana 60 rears. As much as I love the little window cabs it shounds like a parts truck, or maybe a project truck in need of a new cab. Value? $800 & up depending on you location & desire to own such a beast. Does it run & stop?
Americanrider is offline   Reply With Quote
Old 06-28-2006, 01:52 PM   #3
Bob B.
That truck should have a New Process 435 4 speed. Sounds a lot like my truck!
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 06-28-2006, 03:45 PM   #4
shelby987
shelby987's Avatar
it was a camper cruiser.
Parts truck sounds too tough of a term, the rockers and cab corners didn't look that bad, the sunroof was installed "properly" but just looked really out of place.
I agree with the small window, I probably would have just swapped it down the road to remove the sunroof, avoid patching the rockers and cab corners (if necessary) and to get a big back window.
I just wanted to make sure that even with the PB, PS, and the 351 I wasn't walking away from some kind of an unheard of creature.....he wanted $3,000 for it......it was a little high for my taste, especially for having a motor and transmission combo most people tend to shy away from (I liked it, and I know some people on here like it....but he doesn't have to know that!)
Old 06-29-2006, 03:43 AM   #5
Americanrider
Oh yea, I forgot that one is out there, but I pulled this from the Novack site:
The 435 is an excellent, heavy-duty truck transmission designed and used in ½, 3/4 and 1+ ton trucks. It is a well-built transmission and remains easy to locate and generally inexpensive to buy and maintain. The strength, relatively short size and the gearing of the transmission make it a good choice for a variety of situations. The NP435 was made by New Process Gear from 1964 to 1993. They are found primarily in Ford trucks from 1966 to 1992 and Dodge trucks from 1964 to 1993. They also had limited distribution in GM & Chevrolet trucks from 1968-1972. The shifting pattern for the 435 is in the standard "H" pattern with reverse gear being to the right side, and down.
He did say this was a 67, so if it is stock and we assume that Novack is correct it should be a SM420. 3K is a bit steep. I ran accross a 67 GMC Custom Camper in a wrecking yard a while back. It had 305/Th400/PB/PS/3.54 Limited slip. I yanked the rear & PB setup for my 70 GMC shortie.
Old 06-29-2006, 06:46 AM   #6
72ironmike
72ironmike's Avatar
Here is info on one in Iowa that did not sell on ebay. Bid $2350.00. Sounds and look much better than what you describe. Call the numbers below and they will probably send you pics.
Vehicle Description
HERE YOU HAVE AN UNMOLESTED ALL ORIGINAL GMC 1967 PICKUP. THE TRUCK RUNS AND DRIVES LIKE BRAND NEW. AS FAR AS WE CAN TELL IT APPEARS TO BE THE ORIGINAL PAINT. AS YOU CAN SEE BY THE PICS WE ARE SURE THAT THIS TRUCK HAS NOT HAULED VERY MUCH IN THE BACK OF IT. I AM TOLD THAT THE V6 IS KIND OF RARE. BUT WE ARE UNCLEAR ABOUT THIS MAYBE SOME ONE OUT THERE CAN HELP US WITH THIS.WE THINK THAT WEONLY THE THE 3RD OWNERS OF THIS TRUCK.
THIS CAR IS FOR SALE LOCALLY SO WE RESERVE THE RIGHT TO END THE AUCTION EARLY. WE DO NOT WANT ANY MIS UNDERSTANDINGS ABOUT THE ITEMS THAT WE SELL (CHECK OUR FEED BACK)!!! THAT IS WHY WE INCLUDE OUR PHONE # IN THE LISTINGS SO THAT YOU MAY ASK US ANY QUESTIONS THAT YOU LIKE. 319-256-7201DAYS / 319-759-1040 NIGHTS, ASK FOR DAVE.
WE HAVE SHIPPING AVAILABLE EMAIL US AHEAD OF TIME FOR QUOTES
72ironmike is offline   Reply With Quote
Old 06-29-2006, 09:35 AM   #7
JAKES 68GMC
Aluminum slot wheels rule...
Could you possibly get some pics of it? Sounds like a cool truck to me, except for the sunroof. Hint hint CAB SWAP!
JAKES 68GMC is offline   Reply With Quote
Old 06-29-2006, 09:07 PM   #8
Bob B.
Have to say the Novack site is a bit off on this one. G.M.C. favored the NP 435 with the V-6 on 4X2 models from 1965 up. 4X4 V-6's used the Muncie, however. I think the NP 435 might not have been offered in Chevrolet pickups before 1968, though. I just finished rebuilding the NP 435 in my '67.
Old 06-30-2006, 06:13 PM   #9
72fixerupper
tsk, tsk, tsk. Now I got a little warning the one time I tried to ask for an opinion in this forum. you have to pay to get "what it's worth info".
72fixerupper is offline   Reply With Quote
Old 06-30-2006, 06:21 PM   #10
72fixerupper
"Edited by Moderator***
Since you're new here, I'm trying to be gentle. What's it worth post are only allowed in the parts boards. To post there you need to be a subscriber. Subscribe here This is due to misuse by others. We welcome you to the board, and would like you to continue posting."
----BS, BS, BS. Mr Moderator should pull his head out and show some freaking consistancy with "policy".
Old 07-01-2006, 01:29 AM   #11
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
He DID pay, look under his user name. Site Supporter
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-01-2006, 11:04 AM   #12
teeitup
Just like to part out trucks!!
teeitup's Avatar
There is one on ebay right now, ends 7/1 at 3-4 oclock CST, no options but looks clean $999 #220001316379
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 07-01-2006, 11:15 AM   #13
Josh
He's got mean nasty FANGS!
Josh's Avatar
Use a little courtesy and read the rules before speaking. Cya in seven days.
I probably wouldnt give over a grand for that truck, but hard to say without seeing it.
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
