Old 06-28-2006, 12:36 PM   #1
tphsmith
still buypickupparts
tphsmith's Avatar
81 swb fleetside
I am hoping you guys can give me some help!. my brakes are soft, no panic brakes!!!!! what am I missing??. Ive bleed them off several times, no change, Ive exchanged the master cylinder no change. the truck has disk on the front and drum on the back. anyone else have this problem ?
Its Gonna be a Great Day, I woke up this Morning.
72 SWB Fleetside freshly painted. putting a 94 LT1 with
700R4 tranny lowered 4 in the front 6 in the back
81 chevy half ton 350
89 Silverado 4x4 going ta church truck
tphsmith is offline   Reply With Quote
Old 06-28-2006, 04:07 PM   #2
magnethead
7000 #'s of american IRON
magnethead's Avatar
Re: 81 swb fleetside
Did you bench bleed the MC when you put it on? Is it losing fluid, like a bleeder screw or a line is loose? Wheel cylinders?
magnethead is offline   Reply With Quote
Old 06-28-2006, 04:47 PM   #3
tphsmith
tphsmith's Avatar
New rear wheel cylinders, I just replaced wheel bearings this past weekend and the brake lines looked dry, the M/C had been bench bled prior to mounting on the truck, but before the new M/C the brakes were always soft and no panic brakes
Old 06-28-2006, 06:26 PM   #4
84 400
Sb 400 club
84 400's Avatar
ahh mine are also soft but that is because i need new rear pads and drumbs. I am guessing you checked these but how are the pad s and rear drumbs? they may have beened turnned or worn too much.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 06-29-2006, 04:49 PM   #5
tphsmith
tphsmith's Avatar
The drums still have good life in them and the pads are brand new, before I put new rear pads the brakes were still spongie
Old 06-29-2006, 04:55 PM   #6
72 CustomCamper
huh ???
72 CustomCamper's Avatar
It's a stretch but what about the rubber hoses going fron the frame to the calipers and axel? They can soften and flex over time...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 06-29-2006, 05:49 PM   #7
magnethead
magnethead's Avatar
Was there fluid in the MC when you took it off the vise and put it in the truck? If not, theres still tons of air in the line.
Old 07-01-2006, 07:27 AM   #8
tphsmith
tphsmith's Avatar
if there is air in the M/C would you see bubbles in the M/C as you push the brake
